Greetings, I'm wondering about capturing video by the screen capture method. First, is the quality of the capture better with a better monitor at say higher resolution, or is it the graphics card output that is really the important thing? And second, what screen capture software that some of you have used, do you use or recommend?
Results 1 to 1 of 1
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Youtube videos - annoying partial screen
By aelfheah in forum Video Streaming DownloadingReplies: 8Last Post: 13th Apr 2017, 06:10 -
Videos Appear Streched Beyond TV Screen
By ConverterCrazy in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2017, 17:21 -
VSDC Split-Screen and merge videos
By SimBeam in forum EditingReplies: 3Last Post: 18th May 2015, 17:22 -
Best way to record videos for youtube on a laptop screen with fraps
By KeelanM in forum Newbie / General discussionsReplies: 7Last Post: 28th Oct 2014, 23:56 -
Some videos (mp4,avi,etc) do not fill the screen and some do.
By jagman in forum Newbie / General discussionsReplies: 11Last Post: 30th Sep 2014, 20:20
