  1. does the quality option (lowest quality, low quality, normal, high quality, highest quality) really work when u encode a divx with the vcd template??? Ive tried almost all of them and I dont see a diffrence.,,, how can I get the best quality out of a divx movie?...Ive encoded alot of divx movies to vcd and they all have worked fine but the quality looks really bad if the contrast of my tv is high cuz of the bigass pixels u get in the dark scenes of the movies....is there something I can do to make my divx to vcd movies have a better quality????????????
  2. r u using filters? noise reduction is a good filter when doing vcd it helps a bit...
