Hi,
I needed to hardcode custom subs into a video. The trick is however they must have a black textbox in the background; MovieMaker can't do that. I downloaded Aegisubs, which does have the function and made the subs. Next, I used MKVToolNix to merge the subs with the video. It worked: I have a mkv file consisting of the video and the subs. When I'm uploading the video to YouTube, the subs disappear.
This is the 2nd day I'm struggling with this. Help!
Encode your video with Handbrake and hardcode the subs
[Attachment 45882 - Click to enlarge] -
AnonymousGuest
MKVtoolnix does not hardcode subs, it simply adds soft subs to Matroska files.
Use a program that can do what you want, such as Handbrake, Hybrid, MeGUI, etc. -
Not for YouTube they don't. Is that some sort of requirement of your own?
As Marsia Mariner mentioned, that's not hardcoding. They're just embedded, something completely different.Next, I used MKVToolNix to merge the subs with the video.
Use one of the several possible solutions suggested. And there are others -
ASS is not supported by youtube..
You have to burn it in the video before uploading it
https://support.google.com/youtube/answer/2734698?hl=en
Extract hardcoded subs from .avi ?
By maxman32 in forum SubtitleReplies: 5Last Post: 20th Jul 2018, 20:11 -
DVD(Video_ts) with subs to a file with hardcoded subs?
By hech54 in forum SubtitleReplies: 3Last Post: 30th Aug 2016, 15:45 -
How to create a 'highlighted' subtitle to cover over hardcoded subs
By cinesimon in forum SubtitleReplies: 6Last Post: 5th Jun 2015, 01:26 -
Problem with playing AVI with hardcoded subs
By RPB in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2014, 14:25 -
converting mkv or avi to mpeg2 - hardcoded subs not visible
By rogmath in forum SubtitleReplies: 2Last Post: 2nd Nov 2013, 17:01
