Hi!
I'm having a problem with the video, not the sound. Thing is the video gets laggy and pixelated at times on Subtitle Workshop (and Subtitle Edit). Actually, it plays absolutely horribly. The video is animation, cartoons, 23.98 fps and video codec AVC1.
I have ffdshow installed and no problem at all viewing any videos on Windows Media Player, VLC and any other subtitling software except SW and SE.
SW doesn't use Windows Media Player as the internal video player on purpose, according to their own manual. If it did, I wouldn't be having this problem.
I tried to change the internal video player for SW but apparently you can't?
Thing is, I need to use SW because I prefer this platform for subtitling, always use that one. So, I desperately need to solve this.
Any ideas, please?
Thanks so much!
Not a direct answer but a suggestion.
Did you update to the latest version and then find these issues ? According to the update the program had an option to use vlc as a additional renderer. A renderer is NOT a playback engine. And as you already stated vlc plays back your video fine as a standalone.
The additional renderer only uses the 32 bit vlc if installed. So if you have a 64 bit installed that may be the cause of your problem. Install the 32 bit version to see if that solves it.
Or, reinstall an older version which was working fine for you. -
Hi everyone!
Problem solved!I followed a YouTube video and used Tweak Codec to change some settings.
I didn't update anything lately, but maybe the videos were somehow different from what I used before, who knows
Video renderer is VMR9 on SW. And not sure what VLC version I have, but I have hardware acceleration set to automatic and "repair AVI" in the codecs section of VLC.
Basically. what worked was changing ffdshow video decoder/ RAW video/ all supported.
And magically, that fixed it!
Cheers!Last edited by Valerc; 14th Jun 2018 at 07:15.
Hi, there is now also a Subtitle Workshop version that is capable of using VLC as video renderer: https://www.videohelp.com/software/Subtitle-Workshop version 6.0d.
Kind Regards,
Kameleon
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 15:15 -
Can I visualize overlapped subtitles on Subtitle Edit video player?
By brgsbel in forum SubtitleReplies: 1Last Post: 2nd Apr 2018, 17:05 -
How to export a video in Subtitle Edit
By charrua1 in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2017, 16:54 -
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49 -
Subtitle Workshop MP4/MKV video preview problem.
By sinsinati in forum SubtitleReplies: 3Last Post: 4th Nov 2014, 23:19
