  1. Code:
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    File size                                : 219 MiB
    Duration                                 : 2 h 16 min
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 224 kb/s
    Audio
    Format                                   : AC-3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Bit rate mode                            : Constant
    Bit rate                                 : 224 kb/s
    Channel positions                        : Front: L R
    Sampling rate                            : 44.1 kHz
    Frame rate                               : 28.711 FPS (1536 spf)
    Bit depth                                : 16 bits
    Stream size                              : 219 MiB
    I had a hard drive failure recently, so I had to reinstall the OS and I'm not sure if I've got everything set up right. But as far as I know that ac3 file should be fine to go through Encore without transcoding. This one works just fine:
    Format                                   : AC-3
    File size                                : 551 KiB
    Duration                                 : 20 s 160 ms
    Audio
    Format                                   : AC-3
    Bit rate                                 : 224 kb/s
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 spf)
    Bit depth                                : 16 bits
    Stream size                              : 551 KiB (100%)
    EDIT: Bizarre. Seems Audacity changed the sampling rate somehow. I just ran it through again, without even changing anything, and it's fine now.
  2. Sampling rate 44.1 vs 48 kHz
    https://www.videohelp.com/dvd
  3. Yeah, caught that. See my edit.
    No idea how or why it happened.
  4. Mod Neophyte redwudz's Avatar
    USA
    I deleted the duplicate topic post.
    Moderator redwudz
