Hi. I would like to remove the blending in this source. I get decent results with qtgmc.srestore(frate=23.976) but i would like to know if it can be improved.
samples:
http://www.mediafire.com/file/40n08brccnvqvkb/02.demuxed.m2v
http://www.mediafire.com/file/y9vqkd98gku7hrs/01.demuxed.m2v
In addition to the field blending there's some temporal ghosting. I don't see any easy way to get rid of the latter.
I haven't checked the samples but I have never seen a PAL field-blended source where 23.976fps wasn't the right framerate. Anime is created for 24fps and field-blended PAL videos come from those 24 (or 23.976)fps sources. With NTSC sources there might be other possible 'base' framerates, but not for PAL sources (unless from a silent film).
You can confirm by finding a place where there's movement every frame (like a panning shot) and making sure the movement (after being unblended to 23.976fps) is fluid with no duplicate frames or missing frames. -
Yes, the correct frame rate is 23.976. It could be 24 but that's not likely (it's hard to tell the difference). Field blended PAL videos like this usually come from NTSC video tapes passed through a NTSC->PAL converter that blends fields. So 23.976 is almost always right. The first clip (I haven't looked at the second) has some long motion shots where you can see steady motion at 23.976 -- there are no duplicate frames and no jumps in the motion.
But after restoring the 23.976 frame rate many of the frames contain ghosting of previous or later frames, some mild, some heavy, only of moving parts of the picture. That is temporal ghosting (probably from a bad noise reduction filter). Compare that to spacial ghosting where multipath tv reception results in a ghost that's shift slightly to the right (usually) of the main picture, even on still shots. -
Thanks for the info manono and jagabo. I will stick with qtgmc.srestore(frate=23.976). The ghosting was not noticeable on playback.
PAL to NTSC with avisynth - blended frames
By nesburf in forum Video ConversionReplies: 7Last Post: 28th Dec 2017, 00:21 -
Help with detelecine settings: PAL DVD with scene-change field blending?
By U2Joshua in forum Video ConversionReplies: 9Last Post: 22nd Dec 2016, 22:00 -
NTSC blended
By xuguang_he in forum RestorationReplies: 3Last Post: 16th Dec 2015, 13:46 -
Correcting field order for PAL DVD
By VideoPlayout11 in forum Authoring (DVD)Replies: 1Last Post: 26th Mar 2014, 05:13 -
help filtering field-blended dvd source
By beav in forum Newbie / General discussionsReplies: 2Last Post: 28th Aug 2013, 17:58
