Results 1 to 15 of 15
    Jun 2012
    New Zealand
    I Googled for a fix for converting 4:3 to 16:9 but I don't think that is what I want. My file is 'squashed" at 4:3 aspect and just needs widening.
    I have Handbrake and VideoRedo but if either do that I can't see how.
    Any help/suggestions appreciated.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If you were to draw a 4cm by 3cm box on a piece of paper, you can see what needs to be done.
    You need to zoom into the image and lose some of the image's top and bottom.
    Anything else is squashing or stretching.
    The End.
    Jun 2012
    New Zealand
    Not sure I follow.. there's nothing to lose from top/bottom. It *is* stretching that's required as it has been squashed.
    So zooming in will just keep the squashing, yes ?
    But how would that be done? With what.
    Jan 2007
    if it is squashed
    you just want to change the display aspect ratio
    any number of video editing programs can do that
    you can even do that on the fly playing in vlc by going to video, aspect ratio, and select what you want
    i see a lot of youtube videos that have been stretched sideways, old TV clips that have been stretched to 16:9
    people with fat faces, clocks and tires that are oval not round
    try avidemux
    add video filter
    change aspect
    Aug 2013
    Central Germany
    Depending on the formats of the video content or the container, you can even add/edit an aspect ratio flag without any recompression. Especially the MP4 and the MKV container are well supported with tools to edit their attributes with minimal changes. For MKV you may use the mkvtoolnix package, for MP4 you can use MP4Box as CLI multiplexer (or several GUIs if you are not so experienced on the console).
    Unfortunately you did not tell us any technical details (usually a MediaInfo report is the expected minimum) which kind of media file you have.
    Jun 2012
    New Zealand
    Thanks for the tips and links. Will check them out. Yes I see the improvement with VLC. That's my goal to save it like that for viewing on a TV.
    You want a media info file still ?
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I still don't understand whether you are trying to FIX a 4:3 to 16:9 conversion or trying to create one.
  8. Member Cornucopia's Avatar
    Real simple tool to use: math.
    The universal formula
     DAR = PAR * Width / Height
    can be expanded to 2 instances (e.g. DAR1, DAR2) and then find one commonality so you can plug it in, merge them together, and solve for the missing info. Standard algebraic methods.
    Then, most conversion/re-encoding apps can do the job using the new settings arrived at. This works EVERY time.
    Aug 2013
    Central Germany
    @ hech54: Probably just adding a missing AR flag or editing a wrong one.
    @ kirkmc: Yes, a MediaInfo report would help us knowing if either of the mentioned tools can help you, according to the available video content format and container format.
    Jun 2012
    New Zealand
    I am trying to fix a file that's too narrow (squashed). It was created this way, somehow (by someone else). I think it was broadcast in 4:3 format but also squashed further. Playing with VLC Aspect ratio will improve it, but afaik, won't Save it like that. I'd yet to try some of the tools suggested here (thanks).
    General
    Complete name : \\Jill-pc\Movies\AA Series\The Jeremy Thorpe Scandal.mpg
    Format : MPEG-PS
    File size : 691 MiB
    Duration : 1 h 0 min
    Overall bit rate : 1 598 kb/s
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Bit rate mode : Variable
    Bit rate : 1 310 kb/s
    Maximum bit rate : 9 523 kb/s
    Width : 352 pixels
    Height : 288 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.517
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    GOP, Open/Closed of first frame : Closed
    Stream size : 566 MiB (82%)
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.470 System B, BT.470 System G
    Matrix coefficients : BT.601
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Muxing mode : DVD-Video
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 spf)
    Delay relative to video : -30 ms
    Stream size : 111 MiB (16%)
    Menu
  11. If that's really supposed to be 16:9 DAR use DVD Patcher. First make a backup copy. Then open the file in DVD Patcher, change the Aspect Ration to 16:9, Patch: Entire File, Patch: Now.
    Jun 2012
    New Zealand
    Thanks jagabo, I made the adjustments in DVD Patcher and the aspect was much improved, played in Media Player Classic - Home Cinema 1.5.3.370.
    But when played in the TV there was no change at all. I have PC Networked to Rasp Pi and use KODI for streaming.
    Incidentally what does DAR/PAR stand for ?
  13. Display Aspect Ratio, Pixel Aspect Ratio.
  14. Originally Posted by kirkmc View Post
    I was surprised to hear that so I checked on my RPi/Kodi. I saw the same thing. The AR flag was ignored. But VLC doesn't render it properly either. It displayed the video as 2.1:2 DAR, not 1.78:1. I also tried remuxing the video into MKV flagged as 16:9 but the RPi displayed it as 4:3. It looks like you'll have to resize and reencode.
    Jun 2012
    New Zealand
    Thanks for info jagabo. Good to know we're seeing the same thing. Should I now try Handbrake? I'm sure that allows resize but it'd be trial and error here, unless you can suggest some figures ? Or would MP4Box (which I've not used) be preferable?
