    Jun 2018
    Hell
    Downloaded codecs for vdub and it allows me to drag the files in, but it shows them as 0 frames in length, and doesn't display anything. I'm using 600fps clips, which shouldn't be a problem as far as I'm concerned, it just shows a blank gray canvas (uploaded image).
  2. Member DB83's Avatar
    Jul 2007
    I guess you mean filters. Not codecs.
    Just tested on a m4V file on my HDD and it loads fine but it could well depend on the actual codec in your file. If you have not downloaded this one, try the Quicktime filter. There one that explicitly includes M4V
