I'm try to digitize some VHS tapes and have purchased a Sony SVO-5800P broadcast S-VHS recorder. The image quality is superb and it appears to be in fully working condition.
However when I connect it to the Blackmagic Intensity Pro, the image flashes and drops out. I believe this is because it needs to pass through a time base corrector. However... I purchased the SVO-5800P as it is supposed to have a built in time base corrector! (It even states it in the manual).
I've looked at the output on a scope and the signal does seem to be jumping around a fair bit. Am I correct in thinking that a time base corrected signal should be rock solid (apart from the picture part of the signal!)? Ie the voltages shouldn't jump about when you play different tapes from different sources?
Do I need to manually turn the time base corrector on? I couldn't see anything in the manual about this. Or is there another setting I should be tweaking?
thanks, Paul.
The manual touts, "The built-in time base corrector allows you to obtain a stable playback picture with no horizontal jitter or color fluctuation." This tells me that the VCR is using a line-oriented buffer, not a full-frame synchronizer. Moreover, these circuits were designed to provide a good picture on an analog display, which is much more forgiving of timing errors than an analog-to-digital converter. You still need frame synchronization.
Ah thanks for the extra info. That's a shame it can't do it. I'll look into an external time base corrector.
On the right side under TBC control, ensure that the Bypass/Local/Remote switch is in the Local position.
Blackmagic Intensity Pro 4K suddenly starts introducing stutter
By bschneider in forum Capturing and VCRReplies: 31Last Post: 20th Feb 2018, 18:15 -
Blackmagic Intensity Pro - Reducing 1920x1080 Captures to Lower Resolution
By Involuntary in forum Capturing and VCRReplies: 2Last Post: 31st Aug 2016, 04:12 -
BlackMagic Intensity Pro and HDCP
By SSJ Speed Racer in forum Video Streaming DownloadingReplies: 2Last Post: 27th Dec 2013, 00:18 -
Blackmagic Intensity Shuttle
By mayhampixi in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2013, 21:11 -
Blackmagic Intensity Pro Playback in VLC (Win7)
By vin97 in forum Capturing and VCRReplies: 3Last Post: 23rd Jul 2013, 17:08
