I have a .ts file that is about 10 GBytes in size - I need to trim a few minutes from the beginning and end. What's the easiest way to do this? Preferably using a free program but I don't mind paying a few coins for something decent that gets the job done.
Results 1 to 24 of 24
Simplest (and free) program is avidemux (do not worry about the avi bit).
The program has to index the file so a large file will take a minute or two to load. Then you just do an A/B mark edit - A from the start you want to keep and B for the end.
Choose copy for both audio and video and TS muxer for the format and save your new vid -
Yes, definitely.
If this can't handle the file are there any other programs worth trying, even perhaps one that isn't free? (but not too expensive). -
AviDemux never works to edit Transport Streams for me. However, if I convert TS to MKV using Eac3to, AviDemux usually works to edit the MKV. Some TS files I can edit with H264 TS Cutter, which is free. If you only need to trim the beginning and end, TsRemux can usually do that, but you have to play the file in your normal video player and note how many seconds to trim from beginning and ending, then input those times into TsRemux.
For trimming .ts files I use the free SichboPVR. You can download it from videohelp.
Add the .ts file to the SichboPVR recordings folder (click on 'setup' at the top, then on 'advanced', scroll down to 'Recording Folder' for its default location), click on 'Recordings' (at the top) in SichboPVR, then select the .ts file, then click on 'Edit', the basic video editor will open, drag the bar to the start/end of the trim, click on the 'Cut' button, click on the 'tick' symbol to change to 'X' to disable that part of the recording, etc.
Click on the 'Save' button to save to a folder of your choice in lossless quality (no re-encoding is done). -
TS is very tricky as open source multiplexer for TS seem to not exist (at least i'm not aware of any open source working multiplexer - very weird as TS is 30 year old).
I have spent the better part of a week looking for a simple free TS editor. I've been using AviDemux for many years to edit my MKV files but all the forums said although it can edit TS files they usually have A/V sync errors and I tried it and sure enough there are sync errors.....until I realized you can choose the Muxer in the current version and Mpeg TS Muxer (ff) is an option so I tried it and.....Voila! No more audio and video being out of sync so at least I know AviDemux 2.7.5 or new can edit TS files quickly and correctly for free.
You're welcome. There is lots of reading on this issue but nothing but expensive options. I tried every piece of software suggested that was free and all were a bust. I figured that since I found a solution I would share because there have to be other's out there like me who want to edit my files before I compress them, not afterwards and waste time encoding for no reason.
AviDemux with "Mpeg TS Muxer (ff)" is awesome! But many of my files I have recorded off TV have errors in them, and AviDemux glitches and does not save the complete file. Is there an option to use "copy" mode for good parts, and to re-encode (with MPEG-2, of course) only the glitchy parts? (BTW, ss MPEG-2 still copyrighted? It is almost 30 years old now.)
For trimming .ts files, you might want to check out a tool called Avidemux. It's free and pretty straightforward for basic editing tasks like cutting out sections from the start and end of your video. Another good one is HandBrake, although it's more known for format conversion, it can also handle trimming.
You are right, Avidemux and Handbrake are pretty good. If you have error free recordings the results are ok but on ts files with glitches they often fail. I personally hate asynchronous sound during playback, which has happened to me multiple times with Avidemux and Handbrake. What I like on TS-Doctor is the error reporting that most other tools are missing.
For regular cuts and conversions, Avidemux and Handbrake are perfect. -
SolveigMM Video Splitter also natively handles TS
https://www.solveigmm.com/en/howto/how-to-split-mpeg2-file-with-video-splitter/Regards,
Dmitry | SolveigMM | Smart Video Editing (H624/MPEG-2/...)
Very Simple Video Editor
By mjgreer in forum Newbie / General discussionsReplies: 13Last Post: 22nd May 2016, 15:20 -
Simple tu use Audio Editor
By efiste2 in forum AudioReplies: 4Last Post: 12th Feb 2016, 02:54 -
seeking (free) basic video editor for DV AVI
By njitgrad in forum EditingReplies: 7Last Post: 17th Dec 2014, 17:33 -
New simple editor for critique
By Budman1 in forum Latest Video NewsReplies: 23Last Post: 3rd Oct 2014, 10:27 -
Incredibly Simple - Yet Not. Basic Cutting.
By modene1 in forum MacReplies: 10Last Post: 23rd Aug 2014, 10:21
