Hi,
Is there any media player on the market which support Dolby E sound without converting it first on PC?
Thanx for any help
Dolby E is an audio encoding and decoding technology developed by Dolby Laboratories that allows 6 to 8 channels of audio to be compressed into an AES-EBU digital audio stream that can be stored as a standard stereo pair of digital audio tracks.
Up to six channels, such as a 5.1 mix, can be recorded as 16 bit Dolby E data. However, if more than six channels are required, such as 5.1 plus a stereo LtRt, the AES3 data must be formatted as 20 bit audio. This increases capacity to eight channels.
It is very important to ensure that a Dolby E stream is never played through monitors or headphones without decoding. Undecoded Dolby E data will be converted to analog as full scale (0 dBfs) digital “noise” that can easily damage loudspeakers and/or hearing. Unambiguous media labeling is essential to avoid this.
Dolby E never reaches home viewers as it is intended for use during post-production when moving multichannel material between production facilities and/or broadcasters. It is decoded prior to transmission.
Dolby E encoding and decoding is implemented using commercially available hardware or software.
Hardware[edit]
- Dolby DP571
- Dolby DP572
- Dolby DP600
- Dolby DP600C
- Minnetonka Audio SurCode for Dolby E[1]
- Neyrinck SoundCode For Dolby E
- Minnetonka Audio 'AudioTools Server'[2]
- Emotion Systems 'eNGINE'[3]
Source: https://en.wikipedia.org/wiki/Dolby_E
BluRay Player with BDXL Support
By Jake802 in forum DVD & Blu-ray PlayersReplies: 560Last Post: 4th Jul 2025, 12:15 -
What the Formats Does A DVD Player Support
By joseph123 in forum Newbie / General discussionsReplies: 5Last Post: 14th Oct 2017, 23:30 -
Roku 4 Media Player - Dolby Digital woes
By Mark97213 in forum Video Streaming DownloadingReplies: 6Last Post: 18th Nov 2016, 15:55 -
Physical Media Player that supports H.265, 10bit and lossless Dolby/DTS?
By VideoFanatic in forum Blu-ray RippingReplies: 0Last Post: 30th Oct 2015, 13:34 -
Blu-ray player mkv support
By kyrcy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 22nd Dec 2014, 13:37
