Hi People!
For days I have been trying to download a video from an online course in where I'm enrolled.
I tried in all ways to use my credentials (password, login, registration) to download the video, but it fails all the time. I confess that I am kind of noob but I'm trying to read some similar issues...
What I find strangest is being able to see the available formats for download, but not be abble to download it. I can't provide all the comand because there are my credentials, but look:
[generic] SP_6049_050318_TRAB_AULA_01_PT_I_OK: Requesting header
WARNING: Falling back on generic information extractor.
[generic] SP_6049_050318_TRAB_AULA_01_PT_I_OK: Downloading webpage
[generic] SP_6049_050318_TRAB_AULA_01_PT_I_OK: Extracting information
[info] Available formats for SP_6049_050318_TRAB_AULA_01_PT_I_OK:
format code extension resolution note
f3-a1 m4a audio only DASH audio 93k , m4a_dash container, mp4a.40.2 (48000Hz)
f1-a1 m4a audio only DASH audio 127k , m4a_dash container, mp4a.40.2 (48000Hz)
f1-v1 mp4 428x240 DASH video 161k , mp4_dash container, avc1.42c01f, video only
f2-v1 mp4 856x480 DASH video 559k , mp4_dash container, avc1.42c01f, video only
f3-v1 mp4 1280x720 DASH video 1785k , mp4_dash container, avc1.4d4029, video only (best)
After this, when I choose the best video with the best audio:
[dashsegments] Total fragments: 223
[download] Destination: SP_6049_050318_TRAB_AULA_01_PT_I_OK-SP_6049_050318_TRAB_AULA_01_PT_I_OK.ff3-v1.mp4
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 1 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 2 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 3 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 4 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 5 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 6 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 7 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 8 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 9 of 10)...
[download] Got server HTTP error: HTTP Error 403: Forbidden. Retrying fragment 1 (attempt 10 of 10)...
ERROR: giving up after 10 fragment retries
Please can anyone tell me a tip or some way to solve this problem?
Results 1 to 14 of 14
It seems that the program is not passing the log in details.
You could try another program such as this one which is a front-end for youtube-dl which also has inputs for log in details.
https://forum.videohelp.com/threads/382423-YoutubeVideoDownloader-download-video-and-a...from-900-sites
Or, if that fails, you could try a commercial stream recorder such as Jaksta.
Failing all that you can always record the screen as the video plays. -
For both programs, TVDownloader and Jaksta, appears the same error ERROR: Unable to download webpage: HTTP Error 403: Forbidden (caused by HTTPError());
I know I can record the screen, but as it is a large course, it is much faster to download by youtube-dl list as I did earlier, I do not understand this error.
Can you help me? How can i pass a log in details? -
I still don't know how to download
I do not use the program. Twas just a suggestion.
I do use Jaksta and, of course, you would need to be logged in and have the video playing. Not by entering the url in the box.
Even so, I have seen some streams that can not be downloaded hence the fall-back of screen-recording. -
From the youtube-dl documentation:
Authentication Options:
-u, --username USERNAME Login with this account ID
-p, --password PASSWORD Account password. If this option is left
out, youtube-dl will ask interactively.
-2, --twofactor TWOFACTOR Two-factor authentication code
-n, --netrc Use .netrc authentication data
--video-password PASSWORD Video password (vimeo, smotri, youku) -
Fernanda, estou com o mesmo problema.
caso encontre a solução poste aqui por favor.
via navegador eu consegui baixar o MPD para tentar fazer o download via youtube-dl, mas não tive sucesso, caso queira tentar ai
a url do vídeo é:
https://.mpd
o MPD está anexo (compactado)Last edited by BR_QRengaw; 5th Jun 2018 at 15:05.
^^ This is an English-speaking forum. You can obviously read English hence your contribution.
I do not know English, sorry.
Fernanda, I have the same problem.
if you find the solution post here please.
via browser I was able to download MPD to try to download via youtube-dl, but I did not succeed, if you want to try there
The video url is:
https://.mpd
the MPD is attached (compressed)
BY GOOGLE TRANSLATOR
hauhauahua
I believe I had a breakthrough here ...
using this tag, I got a result but I still could not download
D:\tempo>youtube-dl -F --no-cache-dir --cookies cookies.txt "https://.mpd" --add-header "referer:https://
[generic] RJ_6370_041218_ECA_AULA_01_PT_I.mpd: Requesting header
[generic] RJ_6370_041218_ECA_AULA_01_PT_I.mpd: Downloading webpage
[generic] RJ_6370_041218_ECA_AULA_01_PT_I.mpdm: Extracting information
[info] Available formats for RJ_6370_041218_ECA_AULA_01_PT_I.mpd:
f1-a1 m4a audio only DASH audio 134k , m4a_dash container, mp4a.40.2 (48000Hz)
f3-a1 m4a audio only DASH audio 165k , m4a_dash container, mp4a.40.2 (48000Hz)
f1-v1 mp4 428x240 DASH video 151k , mp4_dash container, avc1.42c01f, video only
f2-v1 mp4 856x480 DASH video 503k , mp4_dash container, avc1.42c01f, video only
f3-v1 mp4 1280x720 DASH video 1004k , mp4_dash container, avc1.4d401f, video only (best)
D:\tempo>youtube-dl --no-cache-dir --cookies cookies.txt -f bestvideo+bestaudio "https://.mpd" --add-header "referer:https://"
[generic] RJ_6370_041218_ECA_AULA_01_PT_I.mpd: Extracting information
WARNING: You have requested multiple formats but ffmpeg or avconv are not installed. The formats won't be merged.
[dashsegments] Total fragments: 209
[download] Destination: RJ_6370_041218_ECA_AULA_01_PT_I-RJ_6370_041218_ECA_AULA_01_PT_I.mpd.ff3-v1.mp4
D:\tempo>Last edited by BR_QRengaw; 5th Jun 2018 at 15:08.
Well I believe the issue here is that the id/passwd is for the original website not the server that hosts the videos. That is what these links are referring to.
I guess the website then sends an authorising token to the server to access the content. Since direct access for download is from a different IP to that of the website one gets the 403 - Access Denied
What is the url for the original website ?. No harm in disclosing that since the videos will still not be accessable but they could dowload with the proper credentials through a stream recorder such as Jaksta but only from the original website. -
Well if you really are restricted to two attendances then I strongly suggest you do a screen capture immediately else you will be blocked from further viewing.
And, yes, I guess they changed their security policy due to multiple accesses from shared info.
Edit: Just done a quick conversion of 4000 real to UK£. That's almost £800. At that cost they really should give you more than two views.Last edited by DB83; 5th Jun 2018 at 13:26.
Need help with ffmpeg "HTTP error 403 Forbidden"
By beo59 in forum Video Streaming DownloadingReplies: 21Last Post: 27th Apr 2026, 07:51 -
how to fix "HTTP error 403 Forbidden - Bad Token!!!"
By tom-vin in forum Video Streaming DownloadingReplies: 11Last Post: 16th Apr 2016, 08:26 -
FFMpeg HTTP error 403 Forbidden with akamaihd.net
By theshaft in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jan 2016, 19:43 -
FFMPEG HTTP Error 403 Forbidden for M3U8
By dmpiq in forum Video Streaming DownloadingReplies: 7Last Post: 23rd Jul 2014, 21:03 -
HLS stream capture with ffmpeg not working. HTTP 403 Forbidden error.
By BlueBlack in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Apr 2014, 19:08
