Results 1 to 18 of 18
  1. Anonymous
    Guest
  2. Originally Posted by hello0 View Post
    Comic effect?
    in minute 3:07-3:08
    https://www.youtube.com/watch?v=4AYJZvHeKFo
    I don't see any "effect" at that time ; is this the right link ? or right time ?
    I see some paint at the bottom of a swimming pool, and shallow depth of field, but no "comic" effect
  3. Anonymous
    Guest
  4. It's called over-compression by youtube.
  5. Anonymous
    Guest
  6. It is surely overcompression, check wiki
  7. strong spatial filtering end after edge sharpening - i would try some NLM + warpsharp or overload codec (with strong deblock settings)
  8. This is only partial explanation as important is sharpening before compression (at least it was clearly visible on my browser that face oval edge was sharp) - probably video was sharpened (artificially and too much) before encoding and as result it even emphasised visible overcompression effect.
  9. But there is some "oil painting" too - they all wear makeup, eyeliner etc...
  10. Yeah these KPOP male stars are metrosexuals, so they migh use more makeup than your neighbor's daughter ")
  11. Anonymous
    Guest
  12. Originally Posted by hello0 View Post
    thanks for your answers, yes i meant cartoon effect.
    When i want to use cartoonizer in VD, it says Plugin not recognized. Why?
    I'm using Virtualdub 1.10.4 on my 32 bit system, and copied the 'MSU_Cartoonizer.vdf' file from the 'MSU v.3 zip' folder into the 'plugins32' folder in my Virtualdub directory.
    (I do have to tick the 'force single frame buffer' box in the 'filter options' or the program crashes.....)
    After doing that it all seems to work OK ......
  13. Originally Posted by hello0 View Post
    What is NLM ?
    https://en.wikipedia.org/wiki/Non-local_means
    I haven't seen one for VirtualDub. Try a 2d noise reduction filter with a large radius, moderate threshold. Like Jim Casaburi's 2d Cleaner.
    Re. MSU Cartoonizer: make sure you have the rigth "bitness". 32 bit filter for 32 bit Virtualdub, or 64 bit filter for 64 bit VirtualDub.
  14. Anonymous
    Guest
  15. Anonymous
    Guest
  16. 2d Cleaner only reduces noise. If you want sharper edges you have to do that with another filter.
