Hi,
I'm trying to recode an x265 file which bitrate is too high for my device:
I choose H265-10bit.Code:ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 2 min Bit rate : 89.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.450 Stream size : 76.3 GiB (93%) Language : English Default : Yes Forced : No
The dimension tab shows that the source is 3840x2160, and starts with a 1920x816 odd setting, but I cannot go above 1920 for the output. I'd like to set it to 3840x2160.
What am I doing wrong?
Edit: clicking on another custom preset unlocked the size limitation. I don't know why exactly, but it's working now and I could save a 4K preset.
Resolution is probably limited by the selected preset. You can create a new one which allows higher resolutions.
About HandBrake
By sagor in forum Video ConversionReplies: 12Last Post: 12th Mar 2018, 10:56 -
Besides Handbrake - Any ?
By niteghost in forum Video ConversionReplies: 18Last Post: 9th Nov 2015, 10:08 -
How to set a value for custom cropping with Handbrake nightly build?
By megamani in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2015, 06:20 -
Handbrake Update Has Ruined Handbrake
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 11Last Post: 11th Mar 2015, 14:32 -
Handbrake help
By SwordNeedsHelp in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2014, 12:21
