Suppose I have a one hour long MP4 file that I need to split into multiple files at specific points in time. Is there a free tool that will allow me to input all the points, and have it save all those as individual video files, without re-encoding them? I tried one called MP4 tools, and noticed that some of the files were out of sync (video and audio) Thank you.
without reencoding you can only cut on i-frames, if you also can live with mkv instead of mp4, use mkvtoolnix
Just came across this guide, seems pretty straightforward if it works.
https://forum.videohelp.com/threads/375401-How-to-cut-any-video-with-Xmedia-Recode
It mentions that it can only cut on key frames. Is there one that lets you cut anywhere, and only re-encodes a few frames where the cuts are? -
The software that I know of isn't free but has a free trial. (TMPGEnc MPEG Smart Renderer 5, VideoReDo TV Suite V5, SolveigMM Video Splitter)
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Avidemux works for me. Easy to use, free of charge, and it flags up keyframes, too. . .
I recently split a mp4 with mp4 splitter
By RBCC in forum EditingReplies: 1Last Post: 13th Mar 2017, 03:12 -
mp4 splitter needed
By RBCC in forum EditingReplies: 4Last Post: 5th Jul 2016, 19:18 -
splitter for mp4 files
By RBCC in forum EditingReplies: 6Last Post: 6th Nov 2015, 07:57 -
I need a mp4 Cutter/Splitter
By minegroasprilla in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jan 2015, 17:04 -
using Gabset MP4 splitter
By A700 in forum Software PlayingReplies: 10Last Post: 7th Oct 2014, 11:29
