Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 14 of 14
  1. If i have a printed copy of a Word document, but don't have the original document, i can scan the copy and edit it in Word. If the copy is properly scanned, Microsoft OneNote -- a planner and note taking software included in the Office suite -- can capture text and images and send them to Microsoft Office Word. i should be able to edit the document in Word in less than one minute.
    Please help is above procedure is correct?
  2. I don't know, but why not try? You're not going to break anything.
  3. Originally Posted by ther10 View Post
    The result of the scanning the printed document is a picture, not a text document. You need very smart OCR software to convert the picture to a text document.
    Oct 2005
    666th portal
    that was my though also. i use adobe acrobat to ocr and save scanned papers. it can export as editable docx.
  5. Also some free online websites that can do it too. Google 'PDF to Word'
    Extraordinary claims require extraordinary evidence -Carl Sagan
    Jan 2009
    If you can scan at high resolution with high contrast you may be able to use OCR in some software to copy and paste text. If you have a PDF printed to PDF from Word, you will be able to copy and paste text with higher reliability than OCR unless whoever made the PDF disabled copy and paste.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Might help if you scan it as a high quality TIFF file and then submit that to Google "PDF to Word" ?
    BeyonWiz T3 PVR ~ Popcorn A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 64bit ~ Yamaha RX-A1070 ~ QnapTS851-4G
  8. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I use Abby Fine Reader in conjunction with my Epson V700 scanner. Maybe Fine Reader has a free trial period?
  9. No doubt about high quality of Abbyy Finereader however i would at least give a chance to free Tesseract (some GUI's exist) - after training it should deliver satisfactory results.
    Perhaps if document is not multiple pages (like 100's) then Scribus and/or Inkscape may help (scan, OCR and edition within same editor)?
  10. I guess MS Word will be able to open PDFs and edit them??? I think I tried once and succeeded...
  11. Originally Posted by nharikrishna View Post
    Seriously doubt if MS Word has embedded OCR...
  12. Video Restorer lordsmurf's Avatar
    This is just a spammer.
    He vomited his BS link at the bottom of his first message.
    You're all replying to nobody.
  13. Originally Posted by lordsmurf View Post
    True, but topic may be useful for people in future so my replies are trying to focus on technical aspect.
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    Link removed
