hi, this is my first thread, and sorry i not english native,
i have this problem,
my current hard-disk space is in red,
i have this "homework" of videos about 45gb,
average size of it about 300mb to 900mb(more than 60 movies),
i like split it based scenes transition, then delete the scenes that i dont like,
the software i looking for is :
1. capable to split video based scene automatically
2. capable to multiple files or batch
3. capable to copy splitting (not re-code, because it take lot of time)
optional (no require but, if it have i will super happy):
A. capable to detect if splitting files have complete files(check if there any missing scenes)
B. capable delete original file if condition in point A reached
C free (i dont mind if it batch txt file of ffmpeg syntax)
Results 1 to 30 of 46
I'm working on exactly what you are requesting for the exact same reasons your give (full hard drive, scenes not wanted, etc.) It is far from done yet at least to make it automatic. I can:
Manually list all scene changes (with varying amount of difference selectable)
Manually list all Key Frames (usually always present at Scene change anyway)
Extract the 1st frame of all Scene changes with the time to microsecond embedded in image. (e.g. 327.127127)
Copy exactly from the I-Frame of the wanted chunk up to the I- Frame of the unwanted one.
Unfortunately as I said, it is manual by looking up timings, frame numbers and adjusting the batch files
I know this doesn't help you at this time but you have listed many items that need to be included in the Windows GUI version I have just started to program tonight.
ATM I do not know of other programs that are automated without at least viewing the first frame of each scene. I will add that feature so after looking at the thumbs, it can be checked to auto keep OR delete.
Sorry no help unless you want the batch file scripts but Thanks for the suggestions .
[Attachment 45808 - Click to enlarge] -
There are lots of AVISynth scripts that do scene detection based on the changes in the video itself. I've posted quite a few of my scripts over at doom9.org. This is one such script:
Code:Loadplugin("E:\Documents\My Videos\AVISynth\AVISynth Plugins\plugins\MVTools\mvtools2.dll") SetFilterMTMode("MDegrain2", MT_MULTI_INSTANCE) SetFilterMTMode("MAnalyse", MT_MULTI_INSTANCE) SetFilterMTMode("MCompensate", MT_MULTI_INSTANCE) SetFilterMTMode("MSuper", MT_MULTI_INSTANCE) SetFilterMtMode("AVISource", MT_SERIALIZED) filename = "e:\Scenes.txt" global scenethresh =2.5 #Include decimal point global noise_desns =0.1 #Reduce sensitivity to ratio between two very similar frames (0-3 is good range) BLOCKSIZE = 16 thSCD1 = (BLOCKSIZE*BLOCKSIZE) * 64 source = AVISource("e:\fs.avi").convertTOYV12().killaudio() prefiltered = source.blur(1.0) superfilt = MSuper(prefiltered,pel=2) super = MSuper(source, pel=2) back_vec = MAnalyse(superfilt,isb=true, blksize=BLOCKSIZE,overlap=2,search=0) forw_vec = MAnalyse(superfilt,isb=false, blksize=BLOCKSIZE,overlap=2,search=0) backcmp = source.MCompensate(super, back_vec, thSCD1=thSCD1, thSCD2=255) forwcmp = source.MCompensate(super, forw_vec, thSCD1=thSCD1, thSCD2=255) global mcomp_clip = interleave(forwcmp, source, backcmp) #--------------------------------- #Next six lines let you view the metrics in order to set detection metrics. /* global script = """Subtitle("\nScene = " + String( (YDifferenceToNext(mcomp_clip) + noise_desns)/ (YDifferenceFromPrevious(mcomp_clip) + noise_desns) ) + \ "\nNextSc = " + String( (YDifferenceFromPrevious(trim(mcomp_clip,3,0)) + noise_desns) / (YDifferenceToNext(trim(mcomp_clip,3,0)) + noise_desns)) + \ "\nYDiffN = " + String( YDifferenceToNext(mcomp_clip)) + \ "\nYDiffP = " + String( YDifferenceFromPrevious(mcomp_clip)), lsp=0)""" global metrics = ScriptClip(mcomp_clip,script) final = ScriptClip(mcomp_clip,"""(YDifferenceToNext(mcomp_clip) + noise_desns) / (YDifferenceFromPrevious(mcomp_clip) + noise_desns) > scenethresh \ && (current_frame %3 == 1) \ ? Subtitle(metrics,"New Scene",size=Height/4,align=5) : metrics""") return selectevery(final,3,1) */ #--------------------------------- #Evaluate every 3rd frame using Mod(3) = 1 #Comment out next three lines when viewing metrics with code above #/* WriteFileIf(mcomp_clip, filename, "( (YDifferenceToNext(mcomp_clip) + noise_desns)/ (YDifferenceFromPrevious(mcomp_clip) + noise_desns) > scenethresh) \ && (current_frame %3 == 1)", \ "current_frame/3 + 1", append = false) #*/ # Enable MT! #Prefetch(6) -
Okay here is the first part (batch script) that finds the scene changes equal to .4 (40% different). I have limited the quantity somewhat by allowing to find only up to the first 14,000+ frames (about 8 minutes or 15 I-Frames/250 between each) This is prevent flooding your folder with hundreds of images. It is made to use FFMPEG and FFPROBE in the same folder as the videos. All output will go to this folder as well.
This is a complex script and may fail with different levels of CMD (Mine is 6.1.7601) depending on how it handles quotes, mainly. It creates 2 files in addition to the images. One is the compact output of the scene change frames and all their information. The other is a shortened version for easier reading.
INSTRUCTIONS:
1. @echo off is used to make the output of the CMD window silent. If you have problems comment it out with double colons (::@echo off) to view errors.
2. ::for %%a in (*.mp4,*.mpg,*.flv) Do ( is commented out to use drag and drop function. Drag a video to this CMD and it will run. To use as a batch file uncomment this line and comment the following line. BE VERY CAREFUL IN THIS MODE because FFPROBE is no speed demon and can run for a while on large files before you see any output.
3. select=gt(scene\,.4 can be altered for more or less tolerance to scene changes. .4 is a good start but you may find things like panning a person head to toe changes slowly and may not show the feet as a change from the head since it was done slowly and the percent of change was minor frame to frame. If this is needed change the number to .3 or .2
4. if !sort! GEQ 0 if !sort! LEQ 14000 ( allows output for frames 0 to 14000. !sort! variable keeps track and stops outputting if your file is longer. If you want a longer output or a different segment change as GEQ 14000 if !sort! LEQ 28000.
5. The final :
ause is so you can leave the CMD window open at the finish by uncommenting.
6. fontfile=c:/Windows/Fonts/Arial.ttf may work no matter what you enter here or you may have to change to the location of your font. It depends of your PC and whether it defaults to some font.
If this works and you wish more scripts such as cutting Key Frame to Key Frame or List All frames with type. Let me know. also if you run into problems, please let me or others know so we can fix/help more.Code:setlocal enabledelayedexpansion @echo off set /a count=0 ::for %%a in (*.mp4,*.mpg,*.flv) Do ( for %%a in ("%~nx1") Do ( cd %%~dpa echo. > "%%~na_SceneInfo.txt" echo Scene NO. PTS TIME FRAME TYPE > "%%~dpna_SceneList.txt" ffprobe -v quiet -show_frames -of compact=p=0 -f lavfi "movie='%%a',select=gt(scene\,.4)" >> "%%~na_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %%b in ('findstr /I "type=" "%%~na_SceneInfo.txt"') do ( set "x=%%b" set "y=%%c" set "z=%%d" set "w=%%e" set "v=%%f" set "u=%%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( @echo !count! !x:~13! !w! >> "%%~dpna_SceneList.txt" ffmpeg -ss !x:~13! -i "%%a" -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "%%~dpna_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%%10" if !ekko!==0 echo Frame !count! processed ) ) ::pause -
thanks for reply, i have test this code
and output is :Code:input : "Justice League 2017.avi" size : 1.41 GB (1,522,253,400 bytes)
_SceneList.txt
_SceneInfo.txtCode:Scene NO. PTS TIME FRAME TYPE
yes, only a space and new line,Code:
and this is cmd output :
my conclusion is, this script only detect scene yes?, splitting is using other script,Code:C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>setlocal enabledelayedexpansion C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>set /a count=0 C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>for %a in ("") Do ( cd %~dpa echo. 1>"%~na_SceneInfo.txt" echo Scene NO. PTS TIME FRAME TYPE 1>"%~dpna_SceneList.txt" ffprobe -v quiet -show_frames -of compact=p=0 -f lavfi "movie='%a',select=gt(scene\,.4)" 1>>"%~na_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %b in ('findstr /I "type=" "%~na_SceneInfo.txt"') do ( set "x=%b" set "y=%c" set "z=%d" set "w=%e" set "v=%f" set "u=%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( ffmpeg -ss !x:~13! -i "%a" -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "%~dpna_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%10" if !ekko! == 0 echo Frame !count! processed ) ) C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>( cd echo. 1>"_SceneInfo.txt" echo Scene NO. PTS TIME FRAME TYPE 1>"_SceneList.txt" ffprobe -v quiet -show_frames -of compact=p=0 -f lavfi "movie='""',select=gt(scene\,.4)" 1>>"_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %b in ('findstr /I "type=" "_SceneInfo.txt"') do ( set "x=%b" set "y=%c" set "z=%d" set "w=%e" set "v=%f" set "u=%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( ffmpeg -ss !x:~13! -i """" -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%10" if !ekko! == 0 echo Frame !count! processed ) ) C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>pause Press any key to continue . . .
and it will be nice if it can be batch,
again, thanks a lot for reply, i highly appreciate it. -
You have no -i input. Did you drag and drop a video onto the cmd file? Just running it will not work unless you uncomment the line with (*.mp4,*flv,*mpg) in it AND comment out the line with %~n1 in it. Then it will be a batch file that runs against all mp4,mpg,flv files in the same folder as the cmd file. And yes there is another splitting script but need to make sure you can run this one AS DRAG AND DROP FiRST. Then we know your dos/cmd version handles ok or needs tweaked for quotes.
Try to reread my instructions especially number 2. Your output you sent me had the actual ffmpeg line ffmpeg -i """" because you did not drop a video onto the cmd file. The %~n1 in my script means the file name you dropped on it. If you wish to just run the script as a batch file, uncomment the preceding line by taking out the double colons (:
. Then add double colons to the %~n1 line so it does does execute that line. You will also have to add *.avi so line contains (*.mp4,*.mpg,*.flv,*.avi) so all those file types will be checked and output. But a 1.4 gb will take a while to output as I mentioned in my instructions.
i have try with drag and drop the video to batch file, this is the result :
Justice League 2017_SceneList.txtCode:set "z=%d" set "w=%e" set "v=%f" set "u=%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( ffmpeg -ss !x:~13! -i "%a" -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "%~dpna_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%10" if !ekko! == 0 echo Frame !count! processed ) ) C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>( cd C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin\ echo. 1>"Justice League 2017_SceneInfo.txt" echo Scene NO. PTS TIME FRAME TYPE 1>"C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin\Justice League 2017_SceneList.txt" ffprobe -v quiet -show_frames -of compact=p=0 -f lavfi "movie='"Justice League 2017.avi"',select=gt(scene\,.4)" 1>>"Justice League 2017_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %b in ('findstr /I "type=" "Justice League 2017_SceneInfo.txt"') do ( set "x=%b" set "y=%c" set "z=%d" set "w=%e" set "v=%f" set "u=%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( ffmpeg -ss !x:~13! -i ""Justice League 2017.avi"" -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin\Justice League 2017_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%10" if !ekko! == 0 echo Frame !count! processed ) ) C:\Users\Ujang\Downloads\Compressed\ffmpeg-20180529-cba1679-win64-static\bin>pause Press any key to continue . . .
once again, i am sorry for my reckless,Code:Scene NO. PTS TIME FRAME TYPE
and thanks for your reply and patience. -
You should have a sceneinfo.txt also. What does it show?
i just create a new batch :
and this is the resultCode:ffmpeg -ss !x:~13! -i ""Justice League 2017.avi"" pause
Code:C:\ffmpeg\bin>ffmpeg -ss !x:~13! -i ""Justice League 2017.avi"" ffmpeg version N-91181-gcba167934b Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth libavutil 56. 18.102 / 56. 18.102 libavcodec 58. 19.104 / 58. 19.104 libavformat 58. 17.100 / 58. 17.100 libavdevice 58. 4.100 / 58. 4.100 libavfilter 7. 24.100 / 7. 24.100 libswscale 5. 2.100 / 5. 2.100 libswresample 3. 2.100 / 3. 2.100 libpostproc 55. 2.100 / 55. 2.100 Invalid duration specification for ss: !x:~13! C:\ffmpeg\bin>pause Press any key to continue . . .
i have try with other video and work
Ghost.in.The.Shell.2017_SceneList.txt
Ghost.in.The.Shell.2017_SceneInfo.txtCode:Scene NO. PTS TIME FRAME TYPE 0 144.000000 pict_type=I 1 159.233333 pict_type=I 2 163.366667 pict_type=I 3 165.133333 pict_type=I 4 191.233333 pict_type=I 5 196.333333 pict_type=I 6 198.500000 pict_type=I 7 205.766667 pict_type=I 8 208.800000 pict_type=I 9 210.266667 pict_type=I 570 5834.766667 pict_type=I 571 5846.766667 pict_type=I 572 5850.300000 pict_type=I 573 5858.600000 pict_type=I 574 5866.366667 pict_type=I 575 5870.466667 pict_type=I 576 5873.366667 pict_type=I 577 5879.833333 pict_type=I
note : because too long i trim some of itCode:media_type=video|stream_index=0|key_frame=1|pkt_pts=4320|pkt_pts_time=144.000000|pkt_dts=4320|pkt_dts_time=144.000000|best_effort_timestamp=4320|best_effort_timestamp_time=144.000000|pkt_duration=1|pkt_duration_time=0.033333|pkt_pos=26298306|pkt_size=864000|width=720|height=400|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.513957
and for "Justice League 2017.avi"
i test it why it not work, turn out it not AVI, it MKV rename as AVI
for my reckless, i am really really sorry,Code:Complete name : C:\ffmpeg\bin\Justice League 2017.avi Format : Matroska
The problem is that the AVI had spaces in the filename and the MKV did not. The following should handle files with spaces.. I changed the movie='%%a' to read movie='%~nx1' which will not add quotes to a filename with spaces. the movie=filename must be enclosed in single quotes but movie='%%a' ends up being movie='"C:\ffmpeg\bin\Justice League 2017.avi"' with extra double quotes which caused errors. I also added the line '@echo !count! !x:~13! !w! >> "%%~dpna_SceneList.txt"' so the Scenelist.txt is not empty. Remember that the program only outputs jpg's for scene changes up to 14000 frames. If you want more change the 14000 to a larger number but test first to see how many you get from 14000 first,
Code:setlocal enabledelayedexpansion ::@echo off set /a count=0 ::for %%a in (*.mp4,*.mpg,*.flv) Do ( for %%a in ("%~nx1") Do ( cd %%~dpa echo. > "%%~na_SceneInfo.txt" set "FileName=%%a" echo !FileName! echo Scene NO. PTS TIME FRAME TYPE > "%%~dpna_SceneList.txt" ffprobe -show_frames -of compact=p=0 -f lavfi "movie='%~nx1',select=gt(scene\,.4)" >> "%%~na_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %%b in ('findstr /I "type=" "%%~na_SceneInfo.txt"') do ( set "x=%%b" set "y=%%c" set "z=%%d" set "w=%%e" set "v=%%f" set "u=%%g" set sort=!x:~13,-7! echo !sort! if !sort! GEQ 0 if !sort! LEQ 14000 ( @echo !count! !x:~13! !w! >> "%%~dpna_SceneList.txt" ffmpeg -ss !x:~13! -i %%a -f image2 -q:v 1 -vf "drawtext='fontfile=c:/Windows/Fonts/Arial.ttf:text='!x:~13!':x=(w-tw)/2:y=h-(2*lh): fontcolor=white:box=1:boxcolor=0x00000000@1:fontsize=30" -vframes 1 "%%~dpna_Trim_Thumb_!count!.jpg" ) set /a count+=1" set /a ekko=count%%10" if !ekko!==0 echo Frame !count! processed ) ) ::pause -
Drag and drop just to list:
Code:setlocal enabledelayedexpansion ::@echo off set /a count=0 ::for %%a in (*.mp4,*.mpg,*.flv) Do ( for %%a in ("%~nx1") Do ( cd %%~dpa echo. > "%%~na_SceneInfo.txt" echo Scene NO. PTS TIME FRAME TYPE > "%%~dpna_SceneList.txt" ffprobe -v quiet -show_frames -of compact=p=0 -f lavfi "movie='%~nx1',select=gt(scene\,.4)" >> "%%~na_SceneInfo.txt" for /F "tokens=5,14,15,18,19 delims=|" %%b in ('findstr /I "type=" "%%~na_SceneInfo.txt"') do ( set "x=%%b" set "y=%%c" set "z=%%d" set "w=%%e" set "v=%%f" set "u=%%g" @echo !count! !x:~13! !w! >> "%%~dpna_SceneList.txt" set /a count+=1" set /a ekko=count%%10" if !ekko!==0 echo Frame !count! processed ) ) -
thanks, Justice League 2017.avi now working,
this is first and last 5 line each text :
Justice League 2017_SceneInfo.txtCode:Scene NO. PTS TIME FRAME TYPE 0 18.685000 pict_type=I 1 40.499000 pict_type=I 2 141.600000 pict_type=I 3 149.024000 pict_type=I 4 255.922000 pict_type=I 5 258.508000 pict_type=I 1267 7158.026000 pict_type=I 1268 7160.361000 pict_type=I 1269 7162.113000 pict_type=I 1270 7166.534000 pict_type=I 1271 7175.335000 pict_type=I
Code:media_type=video|stream_index=0|key_frame=1|pkt_pts=18685|pkt_pts_time=18.685000|pkt_dts=18685|pkt_dts_time=18.685000|best_effort_timestamp=18685|best_effort_timestamp_time=18.685000|pkt_duration=N/A|pkt_duration_time=N/A|pkt_pos=4851082|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.497189 media_type=video|stream_index=0|key_frame=1|pkt_pts=40499|pkt_pts_time=40.499000|pkt_dts=40499|pkt_dts_time=40.499000|best_effort_timestamp=40499|best_effort_timestamp_time=40.499000|pkt_duration=N/A|pkt_duration_time=N/A|pkt_pos=9457828|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=1.000000 media_type=video|stream_index=0|key_frame=1|pkt_pts=141600|pkt_pts_time=141.600000|pkt_dts=141600|pkt_dts_time=141.600000|best_effort_timestamp=141600|best_effort_timestamp_time=141.600000|pkt_duration=N/A|pkt_duration_time=N/A|pkt_pos=21864801|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.464162 media_type=video|stream_index=0|key_frame=1|pkt_pts=149024|pkt_pts_time=149.024000|pkt_dts=149024|pkt_dts_time=149.024000|best_effort_timestamp=149024|best_effort_timestamp_time=149.024000|pkt_duration=N/A|pkt_duration_time=N/A|pkt_pos=23207600|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.433801 media_type=video|stream_index=0|key_frame=1|pkt_pts=255922|pkt_pts_time=255.922000|pkt_dts=255922|pkt_dts_time=255.922000|best_effort_timestamp=255922|best_effort_timestamp_time=255.922000|pkt_duration=N/A|pkt_duration_time=N/A|pkt_pos=45491493|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.591469 media_type=video|stream_index=0|key_frame=1|pkt_pts=7158026|pkt_pts_time=7158.026000|pkt_dts=7158026|pkt_dts_time=7158.026000|best_effort_timestamp=7158026|best_effort_timestamp_time=7158.026000|pkt_duration=41|pkt_duration_time=0.041000|pkt_pos=1512493507|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.598615 media_type=video|stream_index=0|key_frame=1|pkt_pts=7160361|pkt_pts_time=7160.361000|pkt_dts=7160361|pkt_dts_time=7160.361000|best_effort_timestamp=7160361|best_effort_timestamp_time=7160.361000|pkt_duration=41|pkt_duration_time=0.041000|pkt_pos=1512756864|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.593984 media_type=video|stream_index=0|key_frame=1|pkt_pts=7162113|pkt_pts_time=7162.113000|pkt_dts=7162113|pkt_dts_time=7162.113000|best_effort_timestamp=7162113|best_effort_timestamp_time=7162.113000|pkt_duration=41|pkt_duration_time=0.041000|pkt_pos=1513013019|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.598409 media_type=video|stream_index=0|key_frame=1|pkt_pts=7166534|pkt_pts_time=7166.534000|pkt_dts=7166534|pkt_dts_time=7166.534000|best_effort_timestamp=7166534|best_effort_timestamp_time=7166.534000|pkt_duration=41|pkt_duration_time=0.041000|pkt_pos=1513591438|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.553892 media_type=video|stream_index=0|key_frame=1|pkt_pts=7175335|pkt_pts_time=7175.335000|pkt_dts=7175335|pkt_dts_time=7175.335000|best_effort_timestamp=7175335|best_effort_timestamp_time=7175.335000|pkt_duration=41|pkt_duration_time=0.041000|pkt_pos=1516657350|pkt_size=2764800|width=1280|height=720|pix_fmt=rgb24|sample_aspect_ratio=1:1|pict_type=I|coded_picture_number=0|display_picture_number=0|interlaced_frame=0|top_field_first=0|repeat_pict=0|color_range=unknown|color_space=unknown|color_primaries=unknown|color_transfer=unknown|chroma_location=unspecified|tag:lavfi.scene_score=0.483217
Great. Just a question but did it create jpg images for those scene changes?
Okay great. Just for information, You can receive less jpg by changing LSS 14000 to a smaller number like LSS 2000. The numbers are the integer of timecode so GEQ 100 ... LSS 200 would mean jpgs and listing between 100 seconds and 200 seconds. Or you can use the other script which just lists without extracting jogs. Thanks
No the jpg is not important. I find it helps me in case several scenes go back and forth several times and i wish to visually see that to cut long repeats out.
Yes script is copy, which is why I began all this research since most copy methods failed me and you lose some quality during recoding. I am still testing with other formats but so far it works with mp4, avc (264), closed gop format. It is complex batch which is also why I am attempting to make a GUI Windows version that will also do batch files. Give me a little more testing and I'll post batch file and then GUI. THANKS
Software for windows besides ffmpeg to split multiple videos?
By carlrandall72 in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2018, 09:43 -
Avisynth, help with scene by scene cropping
By KarMa in forum Video ConversionReplies: 4Last Post: 26th Nov 2015, 10:00 -
Best software for 4-way split screen??
By chazmo7 in forum EditingReplies: 5Last Post: 19th Sep 2014, 10:43 -
Convert DVD Scene to Video
By lomaidala in forum DVD RippingReplies: 14Last Post: 1st Feb 2014, 15:36 -
Looking for software that can split screen for 2 camera recordings
By nickspov in forum EditingReplies: 1Last Post: 2nd Dec 2013, 07:29
