This is called alt mode, and there are some specifications in regards to its operation. Mainly due to hdmi rights restrictions you cant get more than 1.4b output, so theres a 4k@25 limit. What i want to know, since i got a usbc-hdmi dongle for my Samsung Note 8 Mobile
-so the graphics travel until the usbc port, then via the usbc there some kind of a conversion i suppose that transcodes signal to hdmi, and then it gets delivered to the Monitor of preference? So this is not a lossle procedure, in the same way you would have a direct hdmi-hdmi connection right?
-Do i have any control over this type of signal conversion? And is it any better than the smart mirroring, that mobile devices now offer, and Smart TV support internally as well? Reason i ask is i already got smart mirroring working, but then paid for a Samsung DEX, which only did up to fullHD. Was a waste of money, and today i purchased an official Samsung usbc-hdmi adapter. I want to know whats the best way to do this
-What dod i do if i want more than 25fps at 4k coming directly off the phone?
There is no conversion to/from USB for AltMode. Alt Mode allows the USB C port to provide non-USB signals on some of its pins.
If you haven't already done so, you need to check to be sure that Alt Mode is available on your mobile's USB C ports, and that it supports HDMI output. Some USB C connections support DisplayPort Alternate Mode, and other USB C connections are just USB 3.1 ports.
[Edit] I went ahead and looked at the Samsung Galaxy Note 8's specs. The specs say: "With cable: supports DisplayPort over USB type-C. Supports video out when connecting via DisplayPort cable (DisplayPort 4K 60 fps)". I guess the adapter you bought isn't a simple cable and should allow you to connect the phone to a 4K TV. Technically, it must be a DisplayPort 1.2 to HDMI 2.0a adapter.Last edited by usually_quiet; 29th May 2018 at 12:28.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I dont like the 25fps on 4k. Can i at least select somehow a lower resolution, so i can let my TV upscale internally and get mroe fps
Also does anybody know if you can get hdmi-cec on mobile phones, and control media playback apps with a tv remote
NE1 bought one of these? Febon168 HDMI to USB
By sdsumike619 in forum Capturing and VCRReplies: 0Last Post: 13th Jan 2016, 19:28 -
Usb vs hdmi
By mlmiller707 in forum ComputerReplies: 19Last Post: 25th Nov 2015, 20:57 -
Question about camcorder-out HDMI to USB 3.0 capture
By luthierwnc in forum Capturing and VCRReplies: 8Last Post: 18th Mar 2015, 17:51 -
Slightly OT: All these crazy HDMI and USB changes
By ahhaa in forum ComputerReplies: 12Last Post: 11th Dec 2013, 12:24 -
How to connect pc to TV by HDMI cable if the pc has no HDMI but USB port?
By coody in forum ComputerReplies: 3Last Post: 7th Dec 2013, 06:55
