How would you check for an alpha channel in the file below.? It was shot with a Nikon D3200. What does Color space : YUV and how does it relate to RGBA. In vegas right click properties/media/alpha channel says none. I read if there was an alpha channel in an RGBA it would be 32 bits. Where would 32 bits be mentioned?
I want to make something similar to https://www.youtube.com/watch?v=Ti8MoqmQzuM which is from https://forum.videohelp.com/threads/386246-How-can-I-make-this-effect#post2504976
I will be using Vegas 13 Pro. My cameras are Nikon d3200 and Panasonic TZ60. The TZ60 also says colour space YUV
General
Complete name : C:\Users\MYFILM.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2007.09 (qt /niko)
File size : 36.8 MiB
Duration : 13 s 13 ms
Overall bit rate : 23.7 Mb/s
Encoded date : UTC 2014-11-12 11:41:59
Tagged date : UTC 2014-11-12 11:41:59
NCDT : NCTG
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=12
Codec ID : avc1
Bit rate : 22.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.443
Stream size : 34.2 MiB (93%)
Language : English
Color range : Full
Color primaries : BT.709
Matrix coefficients : BT.601
colour_primaries_Original : BT.709
transfer_characteristics_Original : BT.470 System M
matrix_coefficients_Original : BT.601
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 2.38 MiB (6%)
Language : English
YUV is a different color space / color model than RGB, it's usually chroma subsampled to save bandwidth. Most consumer acquistion formats are YUV 4:2:0, where the color information is half width, half height
Cameras usually never shoot with an alpha channel. The exception would be a live key in a studio setup ( e.g. weatherman inside studio, shooting over a background) . If you green or blue screen key, then the keyed out green/blue becomes "transparent" and that transparency information is contained in the alpha channel
Mediainfo does not always indicate if an alpha channel is present for all formats, and even if it does, sometimes it's just a "dummy" or fake alpha channel (not necessarily a valid one). So it's not necessarily a reliable tool. If it does indicate one, it will usually say color space "RGBA" -
Basically, are you looking for a way to have an alpha channel as well as a fill channel coming from the computer and into the ATEM switcher? Are you needing to key the PPT over live video, set it back within live video or??? I'm a bit confused over just what you would need the final composite to look like. Tutuapp 9apps Aptoide
Layering Videos with an Alpha Channel?
By James C in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2015, 10:17 -
Alpha channel!
By alkoon in forum EditingReplies: 5Last Post: 18th Sep 2015, 05:56 -
Test for alpha channel?
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2015, 14:06 -
ALPHA Channel videos - use in Nero 15
By Clark711 in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2014, 21:18 -
What bit depth(s) can a video that has an alpha channel have?
By moonman239 in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2014, 15:46
