I am doing a survey about the high dynamic range capabilities.
Currently the HDR10 can support 4,000 nits of peak brightness and there are not many display can present up to this range.
I am wondering if there are any article that describe the problem if we increase the peak brightness of the display devices (>4,000 nits)?
Many thanks.
Did you try Googling for "display >4,000 nits"?
It show a lot of stuff for you to research at. -
This study was supported by JSPS KAKENHI Grant Number 25135718 to KK, 22135005 to SN. HT was supported by the student fellowship program for leading graduate school at Toyohashi University of Technology. Bluestacks TextNow Photomath
Yes I have found many articles that proposes the advantages of high brightness screen such as excellence image quality under high ambient light.
But currently I need information about the disadvantages in image quality appearance of high brightness display, it's seem like there are not many trusted source that I can reference to. -
Add Dolby Vision which supports up to 12bit color and 10,000 nits to your searches. Also check out avsforums.com as there's more articles and discussions about displays there.
Check Luminance Levels of video?
By mlong30 in forum Video ConversionReplies: 16Last Post: 8th Nov 2018, 11:06 -
Actual luminance of an HDR video
By namdvt in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2017, 02:17 -
What is the maximum luminance value for the ffmpeg blackdetect filter
By alexander121 in forum EditingReplies: 0Last Post: 3rd Dec 2014, 07:05 -
Shooting in 24fps Vs Exporting to 24fps? (Also high frame rate related 120)
By BamBamBigelow in forum Video ConversionReplies: 22Last Post: 17th Nov 2014, 10:21 -
TV screen luminance
By Sonia123 in forum Newbie / General discussionsReplies: 0Last Post: 20th Mar 2014, 22:42
