Hello,
When I ran an .mp4 video file and its .ass subtitle file I created through ffmpeg to merge them, the output video does play in Quicktime Player.
However, I specifically created the subtitles as .ass to specify their positions throughout. When I opened the video in Quicktime, I expected to see a subtitles>English option, but instead it appears as an unknown language.
How do I specify what the subtitle language is in Aegisub?
Did ffmpeg lose the subtitle positions, or does Quicktime Player ignore them?
Thanks for the reply! I may have found the answer to my problem here: subtitles with ffmpeg
It seems that the issue isn’t really with aegisub, but with ffmpeg, which doesn’t support styling/positioning. I was looking into tx3g and found that the encoder mov_txt (which is what I used in ffmpeg) and tx3g are apparently “the same thing”, so I guess my method is still compatible with QuickTime. I’ll look into MP4Box to conserve the styling info.
Position some subs in a BD
By Patapin in forum SubtitleReplies: 9Last Post: 14th Nov 2017, 10:16 -
DVD authoring with [Language Menu] for each [Language Audio]
By Meem in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2017, 04:32 -
Need help with sub-position
By mrgiannis in forum Video ConversionReplies: 4Last Post: 30th Jan 2016, 05:59 -
How can I change position, color and encoding UTF-8 in subtitle Quicktime?
By Jamaika in forum Software PlayingReplies: 0Last Post: 29th Sep 2015, 02:53 -
DVD Info on my laptop conflicting info
By mk1059 in forum MediaReplies: 1Last Post: 22nd Feb 2015, 03:53
