Hello. I have a video file to which I already tried to re-encode with ffmpeg to do so I typed the following command:
However ffmpeg does not continue the process and instead tells me a message which is like this:Code:ffmpeg -i "record_27032018_02240.mp4" -vcodec copy -acodec copy "record_27032018_02241.mp4"
I'd like to know if there is anything that I can use in ffmpeg to "fix" this problem and to en-code the file and skip any errors or discard them as it re encodes the video.Code:moov atom not found
Please I'd like if someone could suggest me an open source software win 7 x86 compatible or something which is free. Thanks in advance.
"Moov atom not found" means the mp4 was not finalized properly. FFmpeg won't fix that.
Do you have the device that this video was recorded on? If you have a good video that was recorded on the same device with the same settings, you may be able to fix the problem video with recover_mp4: https://www.videohelp.com/software/recover-mp4-to-h264 -
Video file damaged after transfer to pc
By Torlon in forum Newbie / General discussionsReplies: 5Last Post: 10th Oct 2016, 20:48 -
Repair damaged MKV file
By robnyt in forum DVD RippingReplies: 1Last Post: 25th Dec 2015, 17:53 -
How to repair a damaged wmv file?
By ericdunn in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2015, 22:49 -
MOV is damaged; repair software says it is not a movie file?
By pennypuncher in forum Newbie / General discussionsReplies: 7Last Post: 5th May 2015, 20:06 -
How to repair a damaged 3gpp files?
By chilliran in forum AudioReplies: 6Last Post: 19th Jan 2014, 05:02
