When using the 2 pass variable bit rate to make a VCD do you need to change the steam type to something other than MPEG-1 Video-CD Standard for it to be effective? Is standard 1150 constant or can it just be 1150 average?
for it to be standard, it must be constant. Alot of players do however accept non standard vcds
So what do you change the stream type to, VideoCD non standard or system VBR or...?
You should use MPEG-1 VideoCD (non-standard) to get the best results.
Regards,
Luis
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 00:49 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16
