I use s_slow to create sort of energy balls with a nice blue glow, and the center is supposed to be white, but when I render it, it looks off. These are my settings:
32bit full range linear setting is the one that makes my source material looks best when rendered...
And now here is the glow issue with different settings. Snapshot means I used the "Save Snapshot to File..." icon which saves the frame and looks exactly as it does in Vegas, to compare it with the rendered frame.
32bit full range (linear)- snapshot (this is how it should look like when rendered)
32bit full range (linear) - render
32bit full range (video) - snapshot
32bit full range (video) - render
32bit (video levels) - snapshot
32bit (video levels) - render
8bit - snapshot
8bit - render
That's all. As you see, when rendered, the white center is lost and it looks like a washed out blue. Also 32bit full range linear has the glow exactly I would like before rendering, notice that the glow is bigger, and part of this glow is lost when rendered.
My source material details:
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : mp4v-20
Duration : 10 s 34 ms
Bit rate mode : Constant
Bit rate : 8 737 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.140
Stream size : 10.5 MiB (100%)
Writing library : Lavc57.89.100
It looks like it's not handling the 32bit linear => 8bit YUV (Rec709) transfer and conversion correctly
Did you try disabling GPU acceleration ? (not just in the export settings, also in the options)
What happens when you export an RGB format, like BMP (not take snapshot, I mean render as)
What is s_glow ? is it 3rd party borisfx/sapphire plugin or something else ? -
Yes, I disabled GPU accel in the export settings, and i just tested again by disabling it in options->preferences->video if that's what you meant, same thing happens, the ball is blue ish inside.
I exported it, the ball looks white inside, but overall picture looks darker, like with a lot of contrast. Default color space option on render settings.
Yes, the sapphire pack. -
I don't know.
I use vegas 13. I don't have that plugin pack for vegas (I have it for AE). But my experience is every version of vegas has had messed up linear workflow compared to other programs. It just doesn't do the linear transfer (to and from) conversions correctly, even from linear assets. Maybe it's fixed since Magix took over, I don' t know . It's one of vegas' weaknesses IMO, it's basically unusable for certain types of work that require linear compositing
You might be able to salvage it if it exports a 32bit linear format correctly, like EXR . Then use another program to do the linear conversion with sRGB gamma and back to YUV.
You can contact borisfx / sapphire for support, maybe they have a known workaround or fix -
How to add this type of "glow" effect? (example, the ki attacks in DBZ)
By rocco123 in forum EditingReplies: 6Last Post: 1st Dec 2016, 11:13 -
H265 - Any tool to make a "smart rendered" cut?
By Seeker320 in forum EditingReplies: 2Last Post: 4th Oct 2015, 20:48 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31 -
Weird "dancing lines" on edges of my video
By cfelicio in forum RestorationReplies: 9Last Post: 5th Aug 2013, 09:18
