I am trying to capture video and audio RAW (or lossless) in ffmpeg which later I will crop and encode. I got it partially working for video which I think is h264 lossless, but audio is lossy.
First time I did this, so not sure how I can set the audio to a lossless format like FLAC or PCM?
HDD space is not an issue as I have an 8TB HDD so raw maybe the best, how do I then convert back to h264/aac?
This works for me which I think is h264 lossless but audio is still lossy.
ffmpeg -f gdigrab -framerate 30 -draw_mouse 1 -i desktop -f dshow -i audio="Stereo Mix (Realtek High Defini" -c:v libx264 -qp 0 -pix_fmt yuv444p -preset ultrafast "out.mkv"
It's generally better to capture and save audio as PCM for VHS captures, I don't know about your setup. You can convert to FLAC after the capture is done with if your wish to cut the audio filesize in half.
Hi KarMa thanks for your reply.
I don't mind using PCM just don't know what the syntax for it would be? IMO I would like to capture video + audio raw and then later edit and compress. Though I use Adobe Premiere to crop/edit not sure it would support PCM or RAW video. So I figured I would convert RAW to high bitrate of h264/aac and then do my editing, cropping etc.
Converting RAW Uncompressed video back to h264 ffmpeg
By TubeBar in forum Video ConversionReplies: 1Last Post: 22nd Apr 2018, 05:45 -
Video capturing old VHS tapes with lossless format
By kur1j in forum Newbie / General discussionsReplies: 32Last Post: 20th Mar 2017, 10:35 -
Adding lossless audio to video / replacing audio track
By Jacobson in forum Video ConversionReplies: 72Last Post: 29th Jul 2016, 21:05 -
I can't see difference between lossless UT video HDMI capturing, and AVCHD
By Stears555 in forum Capturing and VCRReplies: 2Last Post: 20th May 2016, 07:46 -
ffmpeg 2.0.2 vs. 2.1 extracting audio&video from mpls, problem
By Selur in forum Video ConversionReplies: 0Last Post: 2nd Nov 2013, 08:22
