Hi,
Greetings fellas,
Hope you guys are doing well..
I am trying to rip my first blu ray movie.
I have managed to get a remux of the BR disc as a single mkv file of 38GB size using makemkv from the disc.
I did manage to "downrip" this 38GB .mkv file twice, in two steps, to a final size of 11GB which I was quite satisfied with to keep in the HD for archiving purposes.
However, due to sheer stupidity I deleted the files.
Now, VidCoder gives me an error when i try to repeat last time's performance. Something about an header missing or something.
I will post the logs later. Anybody faced the same problem ?
Also, I want to extract the best quality with video bit rate up to 12Mbps including the black bars, ie in full HD 1920x1080 or whatever the exact number is, what i mean is no cropping.. Keeping the audio as passthrough whenever possible.
Anybody wants to give me some tips ?
Thanks,
Been a pleasure to post my first post.
Thank you in advance.
Regards.
You have the MKV file containing the main movie? Does it play properly on the computer?
If so it should not be a problem re-encoding to a smaller file if that's what you want
You can control the cropping in the settings/sizing tab -
My understanding is that he accidentally deleted that MKV file.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Just rip from the blu-ray disc again.
vidcoder encoding
By jucasa666 in forum DVD RippingReplies: 6Last Post: 6th Jun 2017, 23:03 -
Encoding a DVD while gaming? Anything better than Handbrake/VidCoder?
By yuppicide0138 in forum DVD RippingReplies: 10Last Post: 10th Feb 2016, 17:33 -
Video Encoding to 10 bit output using Vidcoder or Handbrake?
By kairukun in forum Video ConversionReplies: 2Last Post: 19th Sep 2015, 09:52 -
VidCoder - Installation error message
By des66_3003 in forum Newbie / General discussionsReplies: 15Last Post: 4th May 2015, 21:42 -
Cancelling VidCoder Encoding
By pizzaboyUK in forum Video ConversionReplies: 11Last Post: 18th Sep 2014, 10:35
