Is there a piece of freeware that will allow me to separate the audio from video and put it into a file then start the audio in the right place where it syncs up the audio with the video? John
Hi,
There must be many such programms and some may be Freeware, like Audacity. I have not worked with Audacity because I work with Sony Vegas Pro. It is not free, but there are a lot of Light versions of Vegas called Movie Studio and they are very cheap. You can edit and apply very many processings both to video and audio tracks in Vegas. When you open a video file in Vegas the audio and video streams are seperated, and placed each in it's own track. So you can ungroup video from audio and cut, split and adjust sync how you like.Panasonic NV-HS860, LG LV 880 HiFi 6 Head, Sony SLV-SE 630 HiFi, LG BL-162W, Sony TRV33E miniDV for Capture, Canopus ADVC 55, Panasonic DMR-ES10, Sony Vegas Pro12, WinDV -
You need video editor - linear (VirtualDub) or NLE - to delay audio by desired time you can use plenty of freeware - sometimes delay is possible without transcoding - depend on container you can modify only PTS.
Can also be done in virtualdub (no longer restricted to avis with the right filters) >> under 'Audio' select 'Interleaving' and you will see 'Audio Skew Correction' with an explanation of how to use it.
You want to yank the audio stream into a separate file for audio/video synching? Not necessary.
What I've used here is Avidemux, which will do straight audio and video format copy, no re encoding. And you can specify a time offset to the audio track to synch it. I've done this a number of times.
To get that time offset I just play the out of synch video in smplayer and manually adjust the audio delay until it's right. Precision to the millisecond isn''t necessary. Then I just copy/paste that value to avidemux.
The only thing is finding the right offset value and some videos are much easier to do this with. The easiest one I did this to was a live concert video, and it was a funk band. And they had dancers on stage. You can't play that stuff without moving something, and they all knew where the downbeat was. Easy. Some videos are a lot harder.
Adding lossless audio to video / replacing audio track
By Jacobson in forum Video ConversionReplies: 72Last Post: 29th Jul 2016, 21:05 -
Encoding Multiple Episodes as Seperate Files
By Chopmeister in forum DVD RippingReplies: 1Last Post: 7th Jun 2016, 04:08 -
Putting Track Markers Without Seperate Tracks In Audacity
By happydog500 in forum AudioReplies: 6Last Post: 25th Oct 2015, 10:20 -
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 7th Aug 2014, 23:10 -
Hey, A couple of questions. 1. when u import a vid can you seperate the sou
By carlyn101 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2014, 19:24
