Here is a straightforward if naive question about ffmpeg:
Is it possible to run a video clip through ffmpeg multiple times without image degradation, or can I expect the video to be degraded slightly with each pass?
I know that crf 0 is "lossless". Is there more to it than that? Will there be chroma subsampling or motion prediction?
For audio I would simply copy the existing audio track.
If you do not save intermediate results using a lossy compression format, or do not alter the video at all, you will not lose quality (up to possible chroma supsampling), but you also will get huge files.
CRF 0 only applies to MPEG video formats AVC/H.264 (or HEVC/H.265), but there are many more lossless video formats.
Which kind of editing do you intend, at all?
If it is multiple cutting, then be aware that the audio track may have different audio frame lengths compared to video frames, so you may introduce asynchronity at cut points if you keep the audio in a compressed format. -
I'm thinking of processing raw camcorder video to begin with, so it's already H.264/mp4, and adding superimposed titles as the second step.
I could go camcorder mp4 -> level-corrected lossless -> lossless with titles. I'm thinking the two lossless steps won't degrade the h.264 any further.
What do you suggest as a lossless format? -
In ffmpeg you have a wide choice with known efficient lossless compression, e.g.: FFV1, Ut Video, Huffyuv (ffvhuf), and also lossless AVC (I would prefer fixed quantizer 0 over CRF 0 here, but the result might be the same). In the MKV container you should be able to mix any of them with any audio track.
Encoding audio in DTS in multi-channels with ffmpeg.
By Malkovich in forum Video ConversionReplies: 20Last Post: 13th Jul 2021, 17:14 -
Mass convert multi 1080p BluRay REMUX AVC to multi 1080p hdlight
By levi59 in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2017, 16:43 -
(Willing to pay)ffmpeg Need help downloading live stream ffmpeg and rtmp
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2016, 16:54 -
FFMPEG QUESTION :How do I take 10bit jpeg with FFMPEG?
By Jamaika in forum Video ConversionReplies: 10Last Post: 6th Jul 2015, 13:41 -
Ogg founder leaves Red Hat, joins Mozilla to work on nex-generation video
By david55 in forum Latest Video NewsReplies: 3Last Post: 22nd Oct 2013, 13:00
