Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    May 2018
    hello!
    i make dvd menus for art performance, so i want a standalone player that i can load my .iso onto, and then navigate the menus with a remote control.
    i don't need blu-ray or HD support, or any streaming.
    this seems like an easy thing to find many years ago, but the media player landscape now is different.
    many players list .iso in their supported media types, but i can't tell if that means menu support.
    any help?
    right now i am looking at this one:
    MXQ PRO S905W Android 7.1 Quad core 4K 1G+8GB DDR4 TV BOX Media WIFI MINI PC 3D
    i know my best bet would be to buy an old player, but they are now so expensive.
    thank you very much!
    Jul 2007
    The latest Kodi on Android is reported to be able to play DVD menus.
    If by old player you're referring to the WDTV Live series, yes they're highly overpriced but keep an eye out and you can find them for <$60 on eBay or Amazon.
    If you're talking about an old DVD player, they're usually <$25 at your local thrift store or sometimes free on Craigslist.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    https://www.avforums.com/review/popcorn-hour-a-500-media-player-review.12623 It plays DVD ISO's and BD ISO's and just about anything you throw at it including H265 but not VP9
    BeyonWiz V2 PVR ~ Popcorn A-500 ~ Samsung ES8000 65" LED TV ~ Sony 75" X9500H ~ Windows 7 64bit ~ Yamaha RX-A1070 ~ QnapTS851-4G
    I've used WDTV for years for this.
    Kodi boxes also do what you want.
    Aug 2006
    I don't have an Android TV box yet, so I have not tried using either of them but if Kodi is not to your liking, VLC for Android and MX Player for Android are supposed to be able to play DVD ISOs.
    May 2018
    when i searched for kodi it installed TVMC, which i guess is related? however it does not seem to be recognizing the .iso file type when i go looking for it in the file manager. the file doesn't show up.
    any thoughts?
    Aug 2006
    any thoughts?
    Uninstall TVMC and download the real Kodi from a trusted source. https://kodi.wiki/view/HOW-TO:Install_Kodi_for_Android
    According to the reviews I found, TVMC's main attraction is that it facilitates finding and watching warez. Kodi is primarily a media player for home theater PC enthusiasts.
    Mar 2008
    I use 9000 kbps in AVStoDVD without problems.
    (Oops wrong thread)
