I mean audieo recorder (home cassette deck), does it have TBC function. I want to buy one. Your opinion is that if the VCR supports TBC, connecting a home recording deck to a VCR can perform TBC on analog audio?
I mean audieo recorder (home cassette deck), does it have TBC function. I want to buy one. Your opinion is that if the VCR supports TBC, connecting a home recording deck to a VCR can perform TBC on analog audio? It seems like I found out that this forum does not discuss the area of digital recording equipment, so I sent it here for the time being. Thank you. I want to buy a home tape recorder that is best equipped with TBC. Thank you
Simple answer: NO.
ALL, EVERY consumer-based analog audio recorder - whether compact cassette, 8-track tape, reel-to-reel, whatever - is basically freewheeling (both figuratively and literally). The best they have to go by is PLL (phase-lock looped) dual capstans & take-up motors.
Only 2" 24track and similar pro recorders use anything resembling crystal clock sync (gen-locked?) or timecode.
Usually, unless your deck is so awful that it has worn out its motors or its capstan size & gripping power, you should not have unmanageable Wow & Flutter (the thing that is exemplified when your timebase varies). Always some in analog, but not enough to worry about.
...Sounds to me like you have some other issue/don't understand what is involved.
Scott -
Mitsubishi Video Cassette Recorder HS-MD3000E-T - Service Manual needed
By MarkO1981 in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2023, 16:05 -
Mitsubishi Video Cassette Recorder HS-MD3000E-T - Service manual needed
By MarkO1981 in forum Newbie / General discussionsReplies: 0Last Post: 8th Aug 2017, 05:11 -
Walkman or Cassette Deck to capture audio on computer?
By digicube in forum AudioReplies: 11Last Post: 26th Aug 2016, 21:28 -
Archiving old VHS footage to digital. Home deck or computer?
By Gil T Remnant in forum RestorationReplies: 4Last Post: 8th Aug 2016, 18:35 -
Toshiba D-VR4XSU HiFi Video Cassette Recorder & DVD Recorder / Player VCR
By fmitchelltx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2016, 21:40
