  1. Hi,
    I just searched this forum and I learned SE can convert ttml+png to sub/idx or sup file.
    I loaded a ttml(xml) file(bunch of png files are in the same folder) in SE, and it shows time marks and seemed each png file is linked to the each time line.
    And.. after that, I don't know what to do to convert them to other formats.
    I exported it as sub/idx and sup but it doesn't show any letters on the video when loaded.
    The exported file seems to have only time marks, not the png images cause when I clicked on Export, it doesn't show any images.
    Could anyone explain how to create a complete sub or sup file with ttml+png?
    Thanks in advance.
  2. I sorted it out.
    It was "Tools - Batch Convert".
  3. Hi, I have seen that you consulted a year ago this topic of converting a ttml + png file in sub / idx format using Subtitle Eddit in "Tools, convert in batches". But I am trying to do the same and it doesn't come out, because I don't know what data I have to put in the output file regarding FORMAT and ENCODER, and CONVERSION OPTIONS. Can you tell me?, thank you!
