This error has persisted for a month. All the uninstall-reinstall gags for Nvidia drivers and the programs in question have failed to fix it. But Potplayer crashes on file close if its settings so much as reference the CUDAs in my 2x1080FE/SLI array. Similar issue occurs with Premiere Pro CC 2018.
Another board suggested, "This looks like a situation of the software needing to update to maintain compatibility with the driver, happens when undefined behavior is patched in client api's that should never have been exploited."
I have no idea how to approach that suggestion. Or, where the issue is being created — video applications? nvcuda.dll? Windows 10? — or where that that mysterious "additional information stored locally" can be found. Can anyone enlighten me? I own 5,120 CUDA cores unusable in these apps!
Thanks!
Michael
Closed Thread
Michael Linder
Currently facing Media Crimes charges
Michael Linder, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/threads/389061-NVCUDA-Unhandled-Exception-Error-crashes-Potplayer
Moderator redwudz
PotPlayer x64 crashes on Windows 10 Creators Update?
By Wilda in forum Software PlayingReplies: 5Last Post: 20th Jul 2017, 09:18 -
Exact audio copy 1.3 crashes -access error violation unhandled exception
By str8arrow in forum AudioReplies: 7Last Post: 7th Jan 2017, 08:25 -
Subtitle Edit 3.4.5 Error : unhandled exception
By PrinceSwaraj in forum SubtitleReplies: 6Last Post: 27th Feb 2015, 11:27 -
Latest version of Potplayer crashes on launch
By mulvya in forum Software PlayingReplies: 3Last Post: 15th Aug 2014, 11:18 -
AutoGK Help, out-of-bounds memory to EXCEPTION: Range check error
By gareen in forum Video ConversionReplies: 7Last Post: 5th Dec 2013, 19:23
