  1. Well as you all know the price on a DVD-R i still a bit high. I know there is a way to burn DVD projects onto CD but i just dont know howto, any suggestions!?
    Regards
    / sweden
  2. burning a dvd on a cd(also known as minidvd) can be done but is nowhere near as compatible as as burning on a dvd-r. But basically it's authored the same way as a dvd but burned on a cd you can only put about 20 minutes worth of video on it tho...
    Hope that helps
  3. Free Flying Soul liquid217's Avatar
    Feb 2002
    http://www.vcdhelp.com/minidvd.htm
    i think you are referring to this
