Hello
A friend of mine asked me this a long time ago, and I didn't know.
I've seen it now again and I remembered about it so I thought I'd ask here because Google was of no help, at least for my way of searching.
As the title says, very often, in old movies especially, when the number 10 appears in a subtitle, the digits are between a space.
Like so
"Goodness...
You say everything 1 0 times over."
Does anyone know why this happens?
I'm hinting on some software bug or something.
I doubt that someone creating subtitles manually would add a space between 1 and 0.
Results 1 to 9 of 9
Since monospaced fonts lack kerning, skinny characters like "1" can look badly set if they are not centered.
Don't know exactly why, but it's an OCR software glitch that I've seen with non-subtitle programs also.
It happens when a subtitle is converted from a bitmapped (image) sub to a text based one. It doesn't only happen with 1 & 0, it can be any number starting with 1. It's probably because the software thinks the "1" is an "I" and separates it from the number(s) following it. -
Has to do with how the spacing of 1 is. If the title has closed captions its not present. Prime example star next generation DVD on stardate "number". Always has a space in OCR. But if I extract the closed captions it not present. Annoying but it is what it is lol
if all else fails read the manual -
I don't think it has to do with spacing as almost all word processing software kerning spaces number and letters correctly.
The font in your CC is probably san serif so the "1" doesn't have the extra line on the bottom making it easier for the software to recognize it as a number and not the letter "I" -
It has to do with whoever is converting the subtitles from graphics based ones and not correcting any mistakes due to the ocr process not being perfect.
When programs do OCR, a lot of the new one ask the USER what it is looking at ...If the user is lazy he will get 1 0 instead of 10..
One can use the subtitle editor's spell check to fix some of these errors...
Movies with CC's, no subtitles
By cornemuse in forum SubtitleReplies: 2Last Post: 5th Mar 2016, 14:10 -
when i download subtitles for movies....
By greeklover in forum Newbie / General discussionsReplies: 9Last Post: 22nd May 2015, 07:24 -
Hardcoding Subtitles to the Movies
By Smoke n Fly in forum SubtitleReplies: 3Last Post: 3rd Dec 2014, 13:03 -
Help needed - editing movies with subtitles
By Doctor Doodles in forum SubtitleReplies: 11Last Post: 24th May 2014, 12:16 -
Burning movies with subtitles?
By legenderycity in forum Authoring (DVD)Replies: 10Last Post: 2nd Apr 2014, 02:25
