hi folks,
i'd like to capture some vhs. i did that in the past with vdub and my "hauppauge wintv go" tv card. but i know that this card doesn't ship a video for windows driver for anything newer than winxp.
soooo... what capture device ships a video for windows driver for win 7 and upwards? (and i don't think, usb devices are fast enough for huffyuv captures).
or are there alternatives to virtual dub which are able to capture in huffyuv and with "normal" WDM drivers?
-benni
There's no problem capturing YUY2 SD video with a USB 2 dongle. I use AmaRecTV instead of VirtualDub.
Most capture cards compatible with VirtualDub use DirectShow drivers. I haven't seen a vfw capture device in 15 years.
You're dead wrong there. Maybe you ain't doin' it right. If you're using WinTv, you're definitely on the wrong track.
http://www.digitalfaq.com/forum/video-capture/7427-capturing-virtualdub-settings.html- My sister Ann's brother -
thanks for your replies...
i was just guessing about the usb adapters as huffyuv transports probably more data than usb 2.0 usually does (~22 MB/sec). but if you say it works, i'd be happy
//edit: used a calculator. from my past experience, it was around 11 mb/sec for a huffyuv capture. so usb works
motivated from your posts i installed my old (old old) wintv go, but i can't find any win7 drivers for it.
do you have a cheap advice for me which device i should buy that works with vdub? maybe even with a component cable input? -
Why do want component cable? What kind of VHS player do you have with component outputs?
2 good performing USB cards win with XP/7/8/10 drivers for VirtualDub or AmarecTV lossless capture. Lossless is used for VHS cleanup, repair, restoration, and final encoding:
Hauppauge USB Live-2: https://www.newegg.com/Product/Product.aspx?Item=N82E16815116048 .
Diamond Multimedia VC500: https://www.amazon.com/Diamond-VC500-Capture-Software-Convert/dp/B000VM60I8?ref=ast_p_ep.
Are these cheap enough? You'll see many threads in this and other forums where people all over the world use these two devices. You can do even cheaper by getting even cheaper, horrible Chinese ripoff copies of these products. So if you're going to get those copies and give your money away for nothing, why not just make a contribution to videohelp?
If you don't intend to cleanup VHS after capture, you don't need lossless capture, and you're wasting your time recording to low-performance lossy b.s encoders like WinTV. Why not just buy a legacy DVD recorder and get a decent recording?Last edited by LMotlow; 18th May 2018 at 16:49.
thanks for your reply, LMotlow.
i have to check which VCR i've stored in the basement. if it has no component output, i have a scart-to-component-converter.
and yes, i want to cleanup / filter the captured material with vdub and/or avisynth. no OEM-software-encoders
if you have even cheaper ones that *work* with vdub, i'm open to suggestions
Xvid 1.3.4 (VFW)
By El Heggunte in forum Video ConversionReplies: 4Last Post: 15th Dec 2017, 13:42 -
Appreciate suggestions devices also capable of capturing/recording BIOS
By vhwul62 in forum Capturing and VCRReplies: 4Last Post: 29th May 2017, 01:08 -
Game HD capture devices (Elgato, Avermedia, Hauppage) for vhs capturing
By videorecover in forum Capturing and VCRReplies: 4Last Post: 7th Jan 2016, 18:48 -
Xvid 1.3.3 (VFW)
By El Heggunte in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2015, 08:29 -
Mp4 compatible with most devices
By cheesycheese in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2013, 09:22
