First time I am making VCD from DVD movie. I riiped the DVd on to my Hard disk using Claddvdxp1.3. It created .d2v and wav file. When I used TMPGEnc to create MPEG-2 file. I got video but not audio. Can any body help me regarding this.
Thanks In Advance. :(
When you open a .d2v file in tmpgenc, all you do is just that. You need to click on the browse button across from audio source and select the wave file that matches your .d2v file.
Thanks John,
I did select d2v in video source and .wav in audio source. But, I am not getting the audio. video quality is very good. -
First off can you play the audio with media player. Just to be sure it's not screwed up and unreadable. If it's playable you could do this. Will only work if you heven't changed the frame rate. The audio will be out of sync if you have. Encode the wave file only in tmpgenc, if it still has no soundc use an external mp2 program like tooLame. Could even be mp3 but thats not the standard. Then encode just the video then you can multiplex them together with tmpgenc's mpeg tools. You can even select the mp2 as your source audio when your encode the video.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
