Results 1 to 12 of 12
  1. I havea corrupted recorded audio file I don't know how to fix any help pls from experts
    USA
    Does it play at all? Assuming it's from a phone, have you tried reading it directly from the phone card?
    If it plays, how is it 'corrupted'? We would need more information, or post the file here.
  3. thank you for your time I will upload the file here
  4. Mod Neophyte redwudz's Avatar
    USA
    I tried to open or view it with several different players and video editors with no luck.
    MediaInfo says its:
    Format : MPEG-4
    Format profile : 3GPP Media Release 4
    Codec ID : 3gp4 (isom/3gp4)
    File size : 2.15 MiB
    IsTruncated : Yes
    No audio shown. I played it with Audacity,
    an audio editor and it just comes out as static noise. So likely it's not an audio file.
    Dropping it into Virtual Dubs HEX editor tells me it not blank and seems to contain data. But I don't understand much of the info.
    I'll post this with your thread and someone else may be able to give better info.
    redwudz
  5. thanks for your time I really appreciate it
    Mar 2008
    The moov atom atom is missing, this contains important info about where everything is.
    Perhaps the OP should try https://www.videohelp.com/software/Video-Repair-Tool but it needs
    a good video from the same device
  7. I will try. but it is an audio file it is phone call recorded
  8. I download the video repair but the file audio did not work
    Mar 2008
    Do you have a similar (from the same device) but working sample you can upload ?
  10. I will upload it now thank you for your help
    Mar 2008
    Take a look at this file, I think at least some of the audio is there. It was produced by the "untrunc" program in Linux,
    which was an interesting exercise to install when you don't really know what you're doing!
    Last edited by davexnet; 8th Jun 2018 at 01:24. Reason: removed the recovered file per the OP's request
  12. thank you very much for the great work and your time you are a Genius I appreciate it very much
