Since megui doesn't support anymore the bluray stream extractor tool, I switched to HD-DVD-Bluray stream extractor v.0.9. But eac3to v.3.34 fails to extract AC3 from DTS and I use v.3.33. Is there sth wrong with the newest version or should I do sth else?
Does anybody recommend another gui application?
MeGUI's HD Streams Extractor is still under the Tools menu and updated more recently than the HD-DVD-Bluray Stream Extractor on which is was originally based.
I assume you're referring to "converting" DTS to AC3, but eac3to 3.34 converts DTS to AC3 for me via MeGUI's HD-DVD-Bluray Stream Extractor. I don't work with Bluray video much these days though. It might be a problem with a specific file or container format, but you haven't supplied much in the way of details, so it's impossible to guess. -
Up in the top left corner there's a Settings menu. It should be a button or there should be a drop-down arrow or something to indicate it's "clickable", but if you didn't know it is, try clicking on Settings and selecting "show all decoding options". Hopefully, that'll be the reason.
Also, in case you didn't know, there was a "+Options" column in the GUI, next to the "Extract As" column, for specifying additional eac3to options, but a menu item to show or hide the column was added to the Settings menu recently, and for some reason it's hidden by default.
Popcorn and eac3to
By marinewonder in forum Video ConversionReplies: 2Last Post: 26th Dec 2017, 05:04 -
EAC3To Incorrect Slowdown? EAC3To Broke?
By TheLastOfThem in forum AudioReplies: 44Last Post: 13th Jul 2017, 20:42 -
Aac eac3to
By TheLastOfThem in forum AudioReplies: 7Last Post: 8th Jul 2016, 15:59 -
eac3to on mkv
By mikehunt69 in forum Blu-ray RippingReplies: 2Last Post: 2nd Jan 2014, 12:02 -
eac3to conversion problem
By dac1 in forum Blu-ray RippingReplies: 0Last Post: 5th Oct 2013, 15:16
