I'm new to the forum so Hi everyone.
I have some CC subtitles and when I use them externally, fine, but if I merge the video and the subtitles together in one file
then the subtitles lines are one on top of the other ... one starts ... stays ... another starts below or up ... that ends and it stays ...
another starts below or up,etc.
I've to say all this is because the subs are overlapping all.I tried sub edit and that fix the overlapping but changes some times and
then i've fix manually that changes...ufffff.
For merge the files i use mkvtoolnix...maybe?
Anyidea?
Greetings.
I don't know if I understood what you mean, but...
Are you opening the video with merged subtitles with the subtitles' file in the same directory? If so, move your video to another place or disable subtitles in your media player. -
Hi,thanks for answering.
Yeap..hmmm....i can read a newspaper o wikipedia more or less well but i've more problems writting,then i've to use
google translate so...google translate regrets his english.
I got the solution but overlapping subs.But the question was if i joined the video with the subs(the idea is to have the subs
embeded for when open the video the subs starts automatically),then there were always two lines in the screen.
you read a line, below it starts another line, when it ends, the previous one take off and start another,etc..
The subs are not being played twice..the subs are being played well but there are always two lines,the line that you are reading and
the previous one.
I can't understand why with the same subtitle but external this does not happen and with the same subtitle but embeded yes,but well...
Yesterday searching here in the forum i saw a post that gave me a clue.With Subtitle Workshop i opened the sub,then Edit,
Timings and Automatic durations and "voilé"...there is not more overlapping,there are no more two lines.
Again,thanks for answering .I give the question for closed but if you want to add something for future members who have doubts
about overlapping...suit yourself,ok.
Greetings.Last edited by Armstrong69; 14th May 2018 at 15:13.
Ok, so it was a problem of overlapping times in the subtitle itself.
That is an easy thing to solve with Subtitle Workshop or Subtitle Edit, it was more difficult to understand what the problem was... :P
Command-line method for correcting overlapping display times? vtt to srt.
By nobodyhome in forum SubtitleReplies: 2Last Post: 15th Mar 2017, 17:36 -
Overlapping frames making blurry shadow when rendering
By Caff in forum EditingReplies: 10Last Post: 4th Dec 2014, 23:15 -
Overlapping two videos
By miscguy in forum EditingReplies: 5Last Post: 21st Nov 2014, 07:08 -
Question about overlapping images in BDN XML+PNG
By sglitch in forum SubtitleReplies: 0Last Post: 9th May 2014, 14:59 -
How do I remove overlapping frames from several video pieces?
By OddTheodora in forum EditingReplies: 4Last Post: 4th Feb 2014, 11:37
