Hello everyone!
I'm trying to perform the deinterlace of the videos below, but in the first video all filters that I tried have no effect. In the second video the filters most only worsen the interlace, the only one that almost removed the interlace was the QTGMC, but it seems to have only merged the frames, leaving a ghost of the previous frame visible.
The second video has a framerate variable up to 50fps, I had never seen a video interlaced with variable framerate, I think something must be done differently to deinterlacing this one. The first video i really dont know why there is no effect.
(The two videos are remux of German blu ray, one of the videos is of volume 1 and the other of volume 10)
Some filters I have tried:
tfm(order=1).tdecimate(mode=1, hybrid=0)
Yadif(order=1, mode=0) # I tried modes 0-3
Telecide(guide=3,post=0,show=false).decimate() # I tried guides 0-3
QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3)
QTGMC(edimode="EEDI3+NNEDI3", preset="Fast")
srestore(23.976)
Code:General Unique ID : 27499638110199657455845480938081413477 (0x14B03CD69B15897A2B57026B3510E965) Complete name : G:\NARUTO\Shippuden 01.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 152 MiB Duration : 5 min 4 s Overall bit rate mode : Variable Overall bit rate : 4 187 kb/s Encoded date : UTC 2018-05-01 17:10:49 Writing application : mkvmerge v22.0.0 ('At The End Of The World') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 5 min 4 s Bit rate mode : Variable Bit rate : 3 727 kb/s Nominal bit rate : 4 512 kb/s Maximum bit rate : 25.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.072 Stream size : 135 MiB (89%) Writing library : x264 core 129 r2245 bc13772 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4512 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 5 min 4 s Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 8.13 MiB (5%) Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 5 min 4 s Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 8.13 MiB (5%) Service kind : Complete Main Default : No Forced : No Text ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 4 min 30 s Bit rate : 22.1 kb/s Count of elements : 77 Stream size : 731 KiB (0%) Default : Yes Forced : NoCode:General Unique ID : 221437335672140332518724957112773851121 (0xA697479116BF724C76135D09681F37F1) Complete name : G:\NARUTO\Shippuden 02.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 123 MiB Duration : 2 min 0 s Overall bit rate mode : Variable Overall bit rate : 8 551 kb/s Encoded date : UTC 2018-05-12 20:12:47 Writing application : mkvmerge v22.0.0 ('At The End Of The World') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 min 0 s Bit rate mode : Variable Bit rate : 5 077 kb/s Maximum bit rate : 25.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 50.000 FPS Original frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.049 Stream size : 72.7 MiB (59%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Codec ID : A_DTS Duration : 2 min 0 s Bit rate mode : Variable / Constant Bit rate : 1 756 kb/s / 1 509 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy Stream size : 25.2 MiB (21%) Default : Yes Forced : No Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Codec ID : A_DTS Duration : 2 min 0 s Bit rate mode : Variable / Constant Bit rate : 1 692 kb/s / 1 509 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy Stream size : 24.2 MiB (20%) Default : No Forced : No Text ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 min 48 s Bit rate : 48.0 kb/s Count of elements : 59 Stream size : 634 KiB (1%) Default : Yes Forced : No
Video 01: https://drive.google.com/open?id=1zXOoEoA2tKNQusCQW8Udizb3S-BxkE5L
Video 02: https://drive.google.com/open?id=1S0clO5H0fBCNyAlS4S7-umkqp3yQv60M
Edit: I forgot to mention, I also tried VIVTC.VFM and Vinverse on Vapoursynth, but both did not work. I do not know how to use Vapour properly, so I used the default setting.
Your samples are not original "BluRay".
mkv can't be used for BluRay.
Variable frame rate can't be used for BluRay.
50fps can't be used for 1920x1080 BluRay.Last edited by LMotlow; 12th May 2018 at 17:34.
- My sister Ann's brother -
This is a German bluray and the both videos are a direct cut from the .m2ts file. I'm trying to work with this because I believe the first episodes should be better than the DVD.
This is the bluray: https:// goo. gl /kLbKnz
Here is a link for the full video in m2ts format: https://mega.nz/#F!kiQX3CgR!rcafrwXieJOnhNtKMIHXjgLast edited by danfgtn; 1st Feb 2020 at 11:52.
Yuck. The first one is poorly upscaled SD. It was done some without deinterlacing first. And before it was upscaled it was frame rate converted with blending. There's no hope. Throw it away. And there's no way it's from a blu-ray release.
The second video was also frame rate converted with blending but it was also sharpened while interlaced -- causing additional ghost like artifacts. You can partially undo that with a Blur(0.1). Try something like:
Code:LWLibavVideoSource("Shippuden 02.mkv") Blur(0.1) Yadif(mode=1) # or QTGMC() SRestore() -
Avisynth separate fields without dominance
By Megafox in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2018, 18:59 -
Variable Framerate to Constant Frame Rate
By jjcinema1 in forum Video ConversionReplies: 5Last Post: 6th Nov 2016, 20:29 -
Variable FrameRate
By Lazare Londaridze in forum Newbie / General discussionsReplies: 111Last Post: 11th Sep 2016, 02:00 -
Need help working with video with variable framerate
By nfshp253 in forum EditingReplies: 8Last Post: 31st Jan 2016, 02:59 -
Variable or Constant Framerate?
By JackDanielZ in forum Video ConversionReplies: 56Last Post: 4th Aug 2015, 07:14
