Hi,
I'm new here and also to video editing.
I would like to edit video clip of david bowie's I'm derailed where you see a car driving at night on a road without lights.
I would like to make a transition from normal "positive" to "negative" over the coarse of the video clip.
I there a software application that supports this? I tried openshot which can apply a Negative filter, but that is applied over the whole clip.
many thanks,
Geert
You can workaround limitations and create signal flow with two videos - first original, second negative copy of original - then you can mix (overlay) video as you wish and where (transition point) you wish.
Note that in the middle of the final result the frame will be flat medium grey.
Flat grey for relatively slow and linear transition - for S curve with sufficiently fast mid part, flat grey can be avoided also S curve is more natural from human perspective than simple linear .
I can't add transition effects to my video edit on Premiere Pro
By d-daniels in forum Newbie / General discussionsReplies: 0Last Post: 14th Jan 2018, 10:56 -
Looking for video player that can transition between clips
By taylor85345 in forum Software PlayingReplies: 6Last Post: 29th May 2017, 11:58 -
Convert Video from Negative Mode to Full Color?
By JonnieGee in forum Video ConversionReplies: 5Last Post: 12th Feb 2016, 14:03 -
Need advice on how to transition from a volunteer video person to a pro...
By underthemountain in forum Newbie / General discussionsReplies: 22Last Post: 22nd Mar 2015, 07:06 -
Adding Transition Effect Between Clips - Video Editor?
By Teac23 in forum EditingReplies: 6Last Post: 19th Sep 2014, 00:31
