Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 111
  1. Well, right click in Vivaldi on links in the F12 network tab does not give me a Copy option but I can use a network sniffer and wait just for the first link so all other ones including the master.mpd will look the same probably
    The RTP channel seems to play some of their videos as mpd, other ones as ts with a m3u8 file (easier for downloading in JDownloader for example) so it is good to have several options to get them
    There is an addon for Firefox called Stream Detector which seems to be able to show the mpd or m3u8 links directly without the need for looking into the source code or the developer tools, maybe not bad sometimes
  2. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    Originally Posted by merula2020 View Post
    Thanks for replying and yes of course, it seems that I was so overwhelmed by these tons of m4s that I just did not look for the master.mpd
    Another stupid question: how do I copy the often very long links found by F12 for master.mpd for example ? Right-click gives me "Reveal" only and I cannot find another option for this (Vivaldi here but will be the same as in Chrome very probably)
    I have the same issue with another RTP Play video (os últimos dias da pide), but I just can't find that .mpd file in network debugging, only tons of m4s files. Is it necessary to playback the entirety of the video? How did you find the mpd file?
    https://www.rtp.pt/play/p6534/e445298/os-ultimos-dias-da-pide
    @jagabo
    Can the same be done with this one as well?
    https://opto.sic.pt/#/play?sid=MTI6NTAxMTZhNTg3YjVkNDgxMjgwMzU0NTdlNmJhMzY2YmU%3D&sNam...Y5ODJjOQ%3D%3D
    EDIT: The Stream Detector did the trick on RTP Play, but not on OPTO's content. The resulting OPTP's -mpd file returns the "no video found" error while using youtube-dl.
    Feb 2006
    @jagabo
    for OPTO'S content, try searching for MP4 and see if that turns up anything
    Mar 2011
    Paris, France
    Hello,
    Here's what Video DownloadHelper in Firefox shows when I'm trying to download a video that's likely DRM-protected:
    Obviously, youtube-dl doesn't work, and no "manifest" shows up when using the Developer mode.
    Is there a way to join all those MP4 chunks into a single file, either within the browser or by reading temp files somewhere on the disk?
    Thank you.
  5. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    Originally Posted by LZAA View Post
    https://opto.sic.pt
    Need access.
    I have access, I'm paying the monthly subscription. Do you wish me to PM you my personal access data?
  6. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    I found a few small MP4 files and, although downloadable, they're unplayable. :/
  7. I do not want anything.
    To solve the problem, I need access.
  8. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    If I don't give you access, then how are you going to get it?
    I agree to provide you the access via PM. Is that OK?
    EDIT: I did notice using network debugging that there are many m4s fragments available. Should I bring all m4s files together by creating a HAR archive, or should I bring all files available together? My problem is that I don't know how to concatenate them all together. Isn't there any other way?
    HAR:
    https://drive.google.com/file/d/1I8fZp-4TPxRjKtgEIDK9RatdzP3177cE/view?usp=sharing
  9. @tugatomsk
    Your RTP problem solved apparently and thanks for the hint to the PIDE doc No problem to get the mpd and downloading it with Youtube-dl but no audio in the file here which seems quite rare at RTP or with Youtube-dl, same thing on your side ? Recommended or easiest way to merge mp4 and m4a anyone ?
  10. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    @tugatomsk
    I also had to merge the resulting MP4 and M4A. I use MKVToolnix which includes mkvmerge, the go-to software to mix several different streams into a MKV file.
  11. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    I guess there's currently no workaround that, is there?....
    Have there been no developments regarding countering DRM protection in recent years?
  12. Originally Posted by tugatomsk View Post
    A successful way of merging init file and m4s segments on Windows for me was using the command prompt and the 'type' command
    type init.mp4 1.m4s 2.m4s > video.mp4
  13. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    I'd be willing to give it a try if it weren't for my inability to extract the content of the HAR file. How can I do so offline?
    HAR:
  14. just use tools already exists for .mpd (assuming you know what you are doing)
    https://gofile.io/d/4pCgbO
    discord=notaghost9997
  15. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    [deleted post]
  16. Member tugatomsk's Avatar
    Sep 2020
    Portugal
    [deleted post]
  17. Hey guys,
    is there a way to download videos from https://www.toggolino.de?
    E.g. https://www.toggolino.de/paw-patrol/paw-patrol-mighty-pups-die-superhunde
    Seems to be segmented and DRM protected so what can I do? I couldn't find any working url with the firefox dev tools.
  18. i could not play the video but i managed to download it.
    https://gofile.io/d/c1URsb (7 days limit)
    url:https://www.toggolino.de/paw-patrol/paw-patrol-mighty-pups-die-superhunde
    mpd:https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/6057955896001/3...Y3ZmNiMA%3D%3D
    kid:key=a75f073f75f743d5a4f264ae75379276:ae658f10b 6994ffb4399948442e43a1b
  19. notaghost thanks a lot!
    But how did you do it? I'd like to get some more vids from that page.
  20. Originally Posted by Callistor View Post
    Find the mpd with f12 network
    You need to use a modified version of youtube-dl that avoids DRM to download the audio and video.
    You also need to use the Widevine decryptor to get the keys.
    Then you need to use mp4decrypt to decrypt the audio and video.
  21. The last answer sounds interesting but a little bit complicated too, maybe I will look for these things.
    One more question for the experts: does this not work because of protection, maybe ?
    https://www.rtp.pt/play/p8622/edicao-especial-um-dia-num-ano-de-pandemia
    Easy to find the mpd but Youtube-DL or 2 different GUI of it cannot get it, I am a little bit surprised that the same channels or tv stations offer things in several different formats and some protected and some not etc., no problem to get other things from RTP for example
    https://streaming-vod.rtp.pt/dash/nas2.share/h264/512x384/p8622/p8622_1_20210316000000...4/manifest.mpd
  22. Code:
    youtube-dl --no-part --restrict-filenames --referer "https://www.rtp.pt/play/p8622/edicao-especial-um-dia-num-ano-de-pandemia" --output "Um Dia Num Ano de Pandemia.ts" "https://streaming-vod.rtp.pt/dash/nas2.share/h264/512x384/p8622/p8622_1_20210316000000e000t0795.mp4/manifest.mpd"
  23. I will try these terrible and often very long command line things but why do GUI like Youtube-dlg or YDL-UI fail and only show errors by entering just the manifest.mpd link beginning with https://streaming-vod.rtp.pt/... ?
  24. Originally Posted by merula2020 View Post
    Because the GUI can't figure some stuff out.
  25. Need argument '--referer https://www.rtp.pt/'
  26. I just wanted to add that I'm having similar problems with opto.sic.it. I can get the MPD link and download the encrypted file but cannnot track the Widevine DRM key unfortunately /I have the tools to get it/. The problem is in the Shaka player they're using. No solution so far.
