  1. I assume it can capture DVCPRO25 and DVCAM.
  2. Member DB83's Avatar
    Jul 2007
    As the old saying goes "In for a penny...." or "If in doubt try it out"
    My take is that as far as the video and main audio tracks are concerned there is little or no difference between the two (of course PRO50 has a higher bitrate so if it works then expect 26 gig per hour files rather than 13)
    And surely the transfer interface is the same IEEE 1394.
    Of course pros would not use this and I doubt if the developer of the program had the opportunity to test it. There is no mention on the web page.
    Hard hat now on as I expect someone who really knows the answer to come and rubbish the above
  3. DV is data transfer, what is inside the stream it doesn't matter.
    Since I can't grab DV on my Windows 10 pro, this was captured over Linux with dvgrab, so if a simple program as dvgrab can, I'm sure any other can also.
    General
    Complete name                            : /media/video/HDD3TB/DV/Work-2002.07.28_00-01-05.avi
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    Commercial name                          : DVCPRO
    Format profile                           : OpenDML
    File size                                : 13.5 GiB
    Duration                                 : 1 h 8 min
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 28.4 Mb/s
    Recorded date                            : 2002-07-28 00:01:05.000
    Video
    Format                                   : DV
    Codec ID                                 : dvsd
    Codec ID/Hint                            : Sony
    Duration                                 : 1 h 4 min
    Bit rate mode                            : Constant
    Bit rate                                 : 24.4 Mb/s
    Encoded bit rate                         : 28.8 Mb/s
    Width                                    : 720 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Original frame rate                      : 29.970 (29970/1000) FPS
    Standard                                 : NTSC
    Chroma subsampling                       : 4:1:1
    Scan type                                : Interlaced
    Scan order                               : Bottom Field First
    Bits/(Pixel*Frame)                       : 2.357
    Time code of first frame                 : 00:00:08;03
    Time code source                         : Subcode time code
    Stream size                              : 13.0 GiB (96%)
    Encoding settings                        : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
    Audio
    Format                                   : PCM
    Format settings, Endianness              : Little
    Format settings, Sign                    : Signed
    Codec ID                                 : 1
    Bit rate                                 : 1 024 kb/s
    Sampling rate                            : 32.0 kHz
    Bit depth                                : 16 bits
    Stream size                              : 499 MiB (4%)
    Alignment                                : Aligned on interleaves
    Interleave, duration                     : 33  ms (1.00 video frame)
    Interleave, preload duration             : 33  ms
  4. Thanks. That's what I thought. Is there a video showing the quality difference between DVCPRO25 and DVCPRO50?
  5. I've read the differences. I just can't find a video so i can see with my own eyes. I assume the difference is small. The closest video comparison I can find is DVCRPRO HD vs DV. https://www.youtube.com/watch?v=4YubZGMFXlQ
