trying to encode this video. using the same method I have used before. I frameserver from virtual dub to CCE and get video file. then I direct stream copy the audio from virtual dub and save as wav. then I use besweet+azid+toolame to change the wave to mp2. then I use pulldown.exe to make it 29.97fps. I then use bbmpeg to bring it all together. with no sound and video delays it is out of sync. so I try again and adjust the delays in bbmpeg and try and delay the video. the result is the exact same and does not change the sync of the audio with the video. I have tried setting the delay to 100 ms different, 5000ms different and it gives me the exact same thing. what am I missing or is there another way to sync a file better????
131 views and no one has another way to sync up audio with video????
***BUMP*** -
Having similar problem i think... I have a 23fps AVI file that i converted to MPG2 with 23fps... No problem there. My problem occurs when I try and convert the MPG2 file or ".mpg" to DVD files such as VOB. I get an out of sync result. I believe that the conversion taking place from ".mpg" to ".vob" is speeding up my fps (frames per second) to around 29fps and leaving the audio far behind. Yes the picture and audio start off the same, but after a minute the audio is behind by 360frames, and increases 360 frames behind each minute...2nd minute 720frames...3rd minute 1080...etc. The solution I am currently attempting is converting from AVI to MPG with 3:2 pulldown feature checked in "other settings" on the TMPGEnc program. Hopefully it works otherwise I'm in the same boat as you. I've gotten other suggestions such as cutting the film up into alot of parts and sync the audio the best i could. (thats LAME) Some where there is someone who knows exactly whats up. Stay the Course. Your cause is just.
Wow that's some BIG text .. heheh
Is your audio at 48kHz or 44.1kHz? If your DVD player is seeing 44.1kHz audio and playing it as 48kHz that would desync the video pretty quickly.
That's the only idea I have on it.
calamari
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
