Hello everyone,
I recently updated to the latest Premiere Pro version 12.1.1 but ever since I did that Premiere only uses the CPU to render.
12.0 did use around 60% of my CPU and some % of the GPU but after the update 0% GPU and 100% CPU.
While this is not a problem by itself, the rendering got a bit slower tho.
When exporting the encoding option only gives me "Only software" and I can't change that. Hovering over that options says that no supported hardware was detected for hardware encoding.
My system:
Win10
Intel i7-8700k
GTX 1080
ASRock Extreme4
16GB DDR4 RAM
Is there a way to enable GPU assisted rendering again?
Thanks in advance.
(I won't downgrade to 12.0 because 12.1 adds support for vfr and I really want that)
Your solution may be here:
Vhttps://forums.adobe.com/thread/24738A88 -
Sorry, I was groggy when I posted the link. Here's the correct link:
https://forums.adobe.com/thread/2473888
And here is the solution that was posted:
Mercury Playback Engine with GPU Acceleration is separate from Hardware-accelerated H.264 encoding.
Hardware-accelerated H.264 encoding (new feature in Premiere Pro 12.1) requires a CPU that supports Intel Quick Sync.
Moreover, Intel Graphics needs to be enabled on your PC (some manufacturers may choose to disable Intel Graphics). -
No problem, thanks for fixing the link.
Hmm, that's strange because before I updated to 12.1 the encoding was hardware accelerated and I didn't change any hardware.
Latest version of PotPlayer 1.657398
By jebirum in forum Software PlayingReplies: 2Last Post: 30th Dec 2015, 14:54 -
ffmpeg latest version?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2014, 16:03 -
boost premiere gpu performance
By rama in forum EditingReplies: 0Last Post: 26th Sep 2014, 08:50 -
Adobe Premiere + GPU Acceleration article(s)
By deadrats in forum Video ConversionReplies: 1Last Post: 24th Apr 2014, 00:39 -
What version of Sony Vegas Movie studio have support for GPU
By Cazz in forum EditingReplies: 3Last Post: 12th Sep 2013, 15:17
