I am new to video capture and want to capture high quality video. I want to capture from my Sony Hi8 camcorder, and VHS player if possible. I am looking for the best capture card. I am not sure about formats, just want quality. I have a small hardrive, so will need a dedicated one. How much will a harddrive cost me that can store 2 hours of digital video? I then want to edit in Premeire and create either VHS or VCD. I have heard about the Pinnacle Studio Deluxe, DV-Hollywood Bridge, and Canupus ADC 100, but don't know much about anyone of them. What other suggestions? Like to keep the card cost below $400. I have a slow computer (P3 850Mgz) so mabybe I need a card that will render itself?
Thanks-
Chris
I just found out the ADVC-100 is firewire, and I don't have a firewire card, so I guess that is out unless firewire is cheap. Is it?
-Chris -
Firewire may be cheap, but it won't be of any use to you.
Firewire transfer is for digital camcorders. Unless you want to get rid of your Hi-8 and buy a miniDV or D8 camera you'll need to use an analog capture card...
Jane -
jane_caldwell,
Firewire card will work with Canupus ADC 100, that converts analog video and audio signals into DV stream. Just read the previous messages. -
Khizhiy,
I was referring to a standalone firewire card (cheap $20 ones), not the integrated cards such as the Canopus ADC which have analog inputs...
Sorry for the confusion, I should have made that clear.
Jane -
I've been using an ATI All In Wonder Radeon, for about two years. It works great, for capturing from my brother's Hi8 camcorder. You can pick up one of the newer versions for under $400.
The size of your hard drive is going to depend on how you plan on editing your video footage. If you're unsure, the bigger the better. Don't forget that you need space on your hard drive for the edited video, as well as the original captured footage.
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 08:03 -
No audio capture from Hi8 camcorder to PC
By dimtechno in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2009, 15:50 -
Not happy with Hi8 to DV capture/conversion results -- Suggestions welcome!
By Hi8 ripper in forum Capturing and VCRReplies: 7Last Post: 9th Jan 2009, 18:21 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 11:57 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 14:24
