Hi there,
I have a problem with the audio files for my project. The audio that was recorded is awful, you cannot understand what the person is saying. Is there any way to fix it?
I've added a sample file just in case.
Thank you in advance.
How did you record the audio? It sounds like it was recorded using a very low quality mic, or the input was too hot so it got distorted.
Take a screenshot of your waveform to see if there's some clipping. It may be possible to fix it to a degree using Ozone, but we need to figure the source of the problem first. -
The Tin-Can-And-String, while reliable and economical, is no longer recommended.
Seriously, there is no clipping. Just a nasty resonance. Sounds like a crappy microphone. -
Hi,
The problem with your audio file is a big distortion, maybe your microphone is not working correctly anymore, or maybe the gain of your amplifier was too high (and the distance between the mic and the person who speaks is too small). Since it's a distortion so the signal is altered and i know no plugin that can correct this..Sorry for that.Last edited by nahnou; 9th May 2018 at 04:45. Reason: spelling error
audio video audio sync problems
By prasoon kumar in forum Video ConversionReplies: 1Last Post: 24th Feb 2015, 02:26 -
Avidemux audio problems. Audio cuts out after a while.
By nobodyhome in forum Video ConversionReplies: 7Last Post: 20th Oct 2014, 23:57 -
AVStoDVD audio problems
By contraplex in forum Authoring (DVD)Replies: 1Last Post: 30th May 2014, 02:14 -
Audio delays/Audio problems
By hafast in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2014, 20:16 -
audio problems when using mkv2vob
By rikki15000 in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2014, 10:08
