I have a section of a movie already properly cut up, so i got a bunch of slices, and this section happens during an earthquake. I wanto apply s_shake on all of these clips, but I was wondering if there is a way to apply this effect with a single s_shake instance so I don't need to load an s_shake instance per cut up click which would be too CPU consuming, also im not sure if the transition from a clip to another clip would be smooth since the s_shake effect is individually applied per-slice.
The only way I see it is to move all these clips into it's own channel and apply the s_shake effect in that channel, but I was wonder if there is a way to do it without having to use it's own channel.
	Are all the clips arranged on a single track ? If so, you can apply effects as a Track FX, instead of individual Event FX's on each individual clip; so that the entire track is affected. You can control this by keyframes (eg strength zero where you don't want it affected)
  Does Vegas pro has this transition effect ?By kwanami in forum EditingReplies: 1Last Post: 28th Nov 2017, 12:10
  Help with adding same text properties to multiple clips (Sony Vegas)By KiwiGaming in forum EditingReplies: 6Last Post: 19th Jun 2016, 06:10
  Underwater effect in Vegas? how to do it?By rocco123 in forum EditingReplies: 7Last Post: 16th Jun 2016, 14:31
  How to create this effect in Final cut(if possible)By Videoday in forum EditingReplies: 5Last Post: 15th Jul 2015, 22:35
  Adding Transition Effect Between Clips - Video Editor?By Teac23 in forum EditingReplies: 6Last Post: 19th Sep 2014, 00:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
