    May 2018
    Argentina
    hi people, fisrt, sorry for my english, i am from argentine!
    I have a video with a subtitle on the bottom, I want to cover it throughout the entire video, I can not find how to do it
    have I explained myself correctly?
    kings regards
    Carlos
    USA
    What format is the video? That makes a great difference for the suggested methods of covering the subs.
    You can use MediaInfo and give us the 'text' output that describes the video.
    One way to cover a sub: Create a black bar in Windows Paint in .png format large enough to cover your sub.
    Then open the video in VirtualDub2 and select the 'logo' filter. Select the saved black bar. Position as desired and save
    a copy of the whole video in the preferred format. You will have to re-encode it so there will be some quality loss.
    You should have a new video with covered subs.
    This is just one way to do it. With better tools, probably some better methods.
    And welcome to our forums.
    It might look like this in VD2. The right side is a preview of the black bar on the video:
    May 2018
    Argentina
    thanks for reply, but, i don`t find logo filter option,
    May 2018
    Argentina
    i found it, but i add the image, but i dont see it
    May 2018
    Argentina
    i can do it, and now, how save the result of this?
    May 2018
    Argentina
    agg simply, only with save is enough, thanks for you help!
  7. Mod Neophyte redwudz's Avatar
    USA
    Good you got started. I had to check if the Logo was part of VD2 or if I had added it.
    The Logo filter is easy enough to use. Of the nine boxes shown, use the bottom middle one,
    then with the x and y offsets to the right you can move it around a bit. For a simple
    black bar, you shouldn't need the other Logo settings. 'Show preview' there will show it on
    your video.
    Then You can use the VD2 'Preview Flitered' in the File column to see
    how it looks through the whole video. If OK, save the video.
    It might take some experimentation to get the right size Logo to cover all the subs.
