Hello
I'm using MeGUI-2836-32
Windows 7 SP1 64
It Started Acting like this from my Last system Restart
not sure what causing this
I hope you be able to help me how to solve this
Thank you
orCode:Problem signature: Problem Event Name: APPCRASH Application Name: MeGUI.exe Application Version: 1.0.2836.0 Application Timestamp: 5adaf7a6 Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.19045 Fault Module Timestamp: 56258e62 Exception Code: c0000005 Exception Offset: 0003d968 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Code:Problem signature: Problem Event Name: APPCRASH Application Name: MeGUI.exe Application Version: 1.0.2836.0 Application Timestamp: 5adaf7a6 Fault Module Name: ucrtbase.DLL Fault Module Version: 10.0.10586.9 Fault Module Timestamp: 5642c5f8 Exception Code: c0000005 Exception Offset: 00086755 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I suspect ntdll.dll errors. Try doing an Internet search for that. It's unfortunately common.
It causes a lot of Windows Explorer crashes also. You can try some of their suggestions,
but beware of any site that has a simple fix for just a few $$.
You can also search for ' what is ntdll.dll '
Other members here may have more specific suggestions.
And welcome to our forums.
yes "ucrtbase.DLL" happen too.
actually it's kind of random which one will be
I tried a lot to search for both files, but usual solution is to reinstall windows and that's something i rather avoid for now
It seems to be a total windows problem, that made some other apps don't work too
one is ESET that can't be launched since then
I send them some logs files ,but they didn't answer yetLast edited by digiraiter; 2nd May 2018 at 21:43.
MeGUI has stopped working
By Bully9 in forum Video ConversionReplies: 5Last Post: 13th Apr 2018, 18:21 -
avs2yuv.exe has stopped working
By vivabarca in forum Blu-ray RippingReplies: 2Last Post: 4th Nov 2015, 17:19 -
AviSynth's MeGUI: how to queue multiple scripts at once?
By Freodon in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2015, 08:06 -
tsmuxer has stopped working
By svsdurant in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Jan 2015, 16:47 -
Starting out with MeGUI which Netframework runtime needed
By loninappleton in forum Video ConversionReplies: 33Last Post: 3rd Sep 2013, 21:40
